587,324 active members*
3,428 visitors online*
Results 1 to 3 of 3
    May 2008
    667
    Turret does not find tool 4 T0404
    It will index to any other tool except tool 4.
    On the main screen, I can see T04 but the turret will not rotate.
    If I ask for any other tools, the turret will index without any problem, any idea.
    Thanks, Jeff
    Aug 2016
    132
    Re: Turret does not find tool 4 T0404
    Sounds like you might have a short for tool 4. With the turret at say tool 1, you should have 0v DC when measuring from J13-3 (tool 1) to J13-11 (0v). Without moving the turret also measure from J13-6 (tool 4) to J13-11. If you have 0v from J13-6/J13-11 then you do have a short. There's a terminal strip inside the back of the turret, you can unhook J13-6 (T4) on first the turret side then the control board side and see which gives you 0v between J13-6 and J13-11 to determine if the short is in the cable or the turret. If it's shorting in the turret, that will be... fun...
    May 2008
    667
    Thanks, your help is appreciated.
  1. Trying to find the name of this tool....
    By cmar143 in forum MetalWork Discussion
    Last Post: 01-07-2017, 05:44 AM
  2. Where to Find Prefab WRL Tool Files for KMontionCNC & How to Rotate Tool?
    By The New Steve H in forum Dynomotion/Kflop/Kanalog
    Last Post: 07-13-2016, 06:02 AM
  3. Aligning turret on a Daewoo Puma 10, 12 tool turret
    By AirChunk in forum Daewoo/Doosan
    Last Post: 06-03-2016, 02:37 AM
  4. Automatic tool changer program for a 8 tool turret Diy lathe cnc
    By tessen in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-04-2014, 05:05 AM
  5. Tool Turret Fault Alarm on TL-1 with no Turret?
    By Edster in forum Haas Lathes
    Last Post: 02-08-2010, 03:35 PM
