603,894 active members*
3,353 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Trying to find the name of this tool....
Results 1 to 12 of 12
    Jan 2017
    4
    I am trying to find out what the name of this tool is to purchase one. I saw a guy using this tool to repair melted battery posts on golf cart batteries but he did not know the name or where it was purchased. My guess is its used in some other application and just fit perfect for use in battery repair thats why I figured someone on this forum would know. The tool is used in the end of a drill and spins like a hole saw however the center is spring loaded and recesses down into the body when you put pressure on it.
    Nov 2007
    71
    Re: Trying to find the name of this tool....
    hmmm it does look like its a boring tool. or a mah plug maker. and it does slide up and down within the outer boring head.
    odd looking tool. Where did you find it?
    Id google out... "old wood boring/drilling tools" or "19th and/or 20th century" something descriptive or other
    Jan 2017
    4
    Centering point is spring loaded and drops down into the body about 3/4" or so as it spins and you put pressure on it. I found a guy using it to repair golf cart battery posts. You use this tool to ream out the round lead lug and there is a new lead piece with a threaded rod that has a hole in it that goes over the battery lug. You then just heat them up and solder together as one piece. On golf cart batteries when the nut comes loose that holds the 6 gauge wires between batteries the connection heats up and totally melts down the lug.
    Sep 2008
    140
    Mar 2007
    2083
    it reminds me of a spotweld cutter I used once -
    Attachment 345556
    your tool looks larger so I guess its more likely a woodworkers tool to produce wooden plugs
    John
    Jan 2005
    15362
    Quote Originally Posted by cmar143 View Post
    It looks like it has been custom made, just for the job, he would of had 2 of them ( 1 ) for the positive terminal and ( 1 ) for the negative, I don't think you will find one just like that and is easy to have someone make it for you if you can't make it yourself, the closest you probably going to get is something like this photo, but would never be as good as what you are showing in your post
    Here is a link to one almost the same as your one
    battery drill post saver,maspmachining.com
    Mactec54
    Jan 2017
    4
    That battery drill post saver bit is exactly what I need, thanks a lot for that link!
    Nov 2007
    71
    if thats the case and this is the tool you actuially need, you should be able to get one at your local tool house. Maybe even a home depot.
    Jan 2013
    630
    That's a left handed, center guided phetzer valve reamer.
    Jan 2017
    4
    I actually brought that picture to home depot and they didnt have anything like it, pointed me to hole saws. I wish there were more options as the one for sale in the link is $105 which seems pretty expensive to me
    Jan 2005
    15362
    The only option is for you to make it yourself, or have a friend make it if you can't, it's very easy to make, it will have a taper machined inside to match the battery post, a center plunger with a spring to keep it centered on the post
    They are like I said custom made, only someone repairing batteries would have a use for them, they are easy to make just take some time to do, and time is money, you won't find them in any stores like home depot or auto supply stores, custom made for something like this, is you buy it from whoever makes it
    Mactec54
    Aug 2007
    6
    edit:
    oops, I commented before I looked at the picture full size.
    Thought it was a birdcage...
  1. Where to Find Prefab WRL Tool Files for KMontionCNC & How to Rotate Tool?
    By The New Steve H in forum Dynomotion/Kflop/Kanalog
    Last Post: 07-13-2016, 06:02 AM
  2. alarm 1075 cant find tool
    By littlenoz in forum OKK
    Last Post: 01-04-2016, 03:10 AM
  3. Can't find this tool in Mastercam
    By Technical Ted in forum Mastercam
    Last Post: 01-06-2013, 06:49 PM
  4. Need to find best tool for my first CNC
    By manekibusiness in forum MetalWork Discussion
    Last Post: 04-14-2011, 03:06 PM
  5. Can't find this tool to measure the I.D. of tubes anywhere..
    By squale in forum MetalWork Discussion
    Last Post: 02-18-2010, 03:05 AM
