587,850 active members*
2,930 visitors online*
Thread: Mori Seki
    Oct 2006
    340
    Mori Seki
    How much concrete would I need for a 20,000 lb Mori Seki vmc, I have a 6" pad and a 12" pad that it will fit on. I assume the 12 would be better but the location might be tight.
    Feb 2009
    6028
    What machine? Is the 6" reinforced? Obviously thicker is always better...
    I've put MV653's on 6" reinforced without issues, although its not recommended.
    Oct 2006
    340
    MORI SEIKI MV-40 B, I may have been off on the weight It is around 14,000 lbs, I have a 12" reinforced pad I thought was 6" it will work just fine. Thanks for taking the time.
    Feb 2009
    6028
    6 leveling pad machine, no problem even on 4" if you have to. Think those were 12,500#
  1. Mori Seki - Fanuc 11T
    By brourke in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-15-2014, 05:14 PM
  2. Mori Seki SL-O H/Fanuc how to upload pro?
    By beckylee in forum Fanuc
    Last Post: 11-15-2009, 12:58 AM
  3. Mori Seki Sl-15 Machine Parameters
    By MILLMANM in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-25-2007, 01:36 AM
  4. Replies: 3
    Last Post: 03-19-2007, 04:27 PM
  5. Mori Seki SL4
    By programmer1956 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-08-2007, 11:22 PM
