588,551 active members*
5,586 visitors online*
Threaded View
    Jan 2007
    435
    Material ID/Capacity Question
    I'm curious if any of you might have a clue as to the material this item is made from. It very much looks and feels like aluminum however it has a very odd gold tint to it. The attached photo is very representative of what the metal looks like in real life. At first I thought maybe it had some type of zinc chromate treatment. It almost looks like it's very lightly gold anodized. I'm pretty sure it's aluminum but not sure if it's the standard 6061.
    I'm also curious what anyone thinks the weight bearing capacity is. For clarification, this is an aircraft jack adapter. The aircraft this is made for sits too low to the ground for a typical aircraft jack to jack it up. The protruding cylinder fits in the wheel axle and the jack goes under the half sphere at the top. I'm looking at creating one of these myself out of 6061 but I'm curious what the weight bearing capacity would be. The part is uniformly thick except for the tapered "nose" at the top where the half sphere is at. Other than this tapered nose, it's about 2 to 2-1/1 thick. Any help or suggestions are appreciated.
  1. Dumb Question Regarding Machine Capacity
    By Eric MFG in forum Knee Vertical Mills
    Last Post: 11-11-2009, 07:55 PM
  2. Belt material question?
    By satguy in forum DIY CNC Router Table Machines
    Last Post: 06-20-2009, 02:45 PM
  3. RF45 Oil Capacity
    By ranchak in forum Charter Oak Automation Support Forum
    Last Post: 06-06-2009, 07:04 AM
  4. Material strenght question...
    By croosh in forum DIY CNC Router Table Machines
    Last Post: 02-20-2008, 02:41 AM
  5. Material for lathe bed question
    By jdholbrook in forum Uncategorised MetalWorking Machines
    Last Post: 05-01-2006, 05:05 PM
