588,656 active members*
5,971 visitors online*
Thread: Hoss's G0704
Page 170 of 344 70120160168169170171172180220270
Results 3,381 to 3,400 of 6871
  1. #3381
  2. #3382
    Feb 2012
    234
    That package is awesome. I will be calling keling soon I want to pretty much use that kit but with a ethernet smooth stepper and a c32.
    Any way Hoss so I am contacting grizzly tomorrow to see about exchange but while all that is going on I would like to get a jump on the enclosure for the cnc. Dose your pan prints included on dvd take into account the y extension piece? Cause if it does I can start working on that and ordering electronics.
    Also what kind of paint did you use on your wood to seal it from oils and cutting fluid, oil based or spray enamel?
    thanks
  3. #3383
    Quote Originally Posted by Whizbang View Post
    thanks
    Good idea to let grizzly know, they may fix you up right.
    The tray was for the stock mill with front stepper.
    The width is just right to sit atop the pan on the stand.
    For the y extension just put a big notch in the rear of the tray to clear the column.
    Probably need to seal around the column and y spacer.
    I used marine topside paint, very tough stuff.
    Blue Water Marine Mega Gloss
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  4. #3384
    Aug 2010
    278
    thanks
    I have the exact same package with a Ethernet smooth stepper, but instead of the KL-5056D, i got upgraded to the KL-8056D thank you Keling
    Hive 8 - G0704 CNC Mill - 20 inch Telescope - High Resolution 3D Printer - Lasersaur 100W CO2 Cutter / Engraver
  5. #3385
    You should note that using a 5.6 amp driver for the 906 oz/in nema 34 stepper limits it to 831 oz/in.
    I recommend using the 8070D to get the full torque from the motor.
    Hoss
  6. #3386
    For the Roton nut .1270 balls are good to go, .1280 not so much.
    Just double checked Tool supply on Ebay and don't see either the .1270 or .1280 balls now,
    I only bought one package each so don't blame me.
    Better email him and ask if he plans to get more, .1270's at least.
    Hoss
    [ame="http://www.youtube.com/watch?v=bcjKULKKudw&list=UUjoRKEpk7uE5Wzf4b-IFTFg&index=1&feature=plcp"]G0704 Roton Ballnut Max Oversize Balls - YouTube[/ame]
  7. #3387
    I emailed Tool Supply, the .1270 and .1280 balls are relisted.
    Ballscrew Ball Screw Balls 100 pcs 0.1270 (mm3.2258) | eBay
    Hoss
  8. #3388
    Dec 2009
    1416
    Thanks for the heads-up! I just grabbed a bag of 100 for mine since they were not available when I originally installed it all. Got to redo the Y screw someday anyhow so I will hold on to these till it's time to break the mill down to go to the new outdoor shop.
    CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
  9. #3389
    Yeah the .1270's feel real good and should have almost zero backlash.
    Hoss
  10. #3390
    Feb 2012
    234
    Quote Originally Posted by hoss2006 View Post
    Hoss
    Would .1275 be perfect if they could be found? What about using double nuts?
    obviously everyone wants the most accurate machine possible. If you get some figures on backlash please post them. From what i can tell many of us are at the buying electronics and upgrading screws stage of out build.
    Hoss thanks for leading the push for g0704 improvement
    Whizbang
  11. #3391
    Whizbang
    Probably not maybe .1272 would squeeze in there and still spin, the .1280 had to be forced.
    Don't want any binding risk.
    Double nuts could use the stock balls but 2 nuts would take up more room in an already tight area, no problem for the z though.
    .1265 balls got me .0008 backlash before so I don't bother with comp that small.
    I'll change to .1270's on the machine next teardown for whatever.
    Been over 2 years now of testing things on the 0704. I'll keep at it as ever newer items come along just like these balls.
    As bigger ones became easily available, I got some to try out.
    Trying to get a quote from Nook like I did years ago for the X2 on the costs for a set of XPR screws and nuts
    but they only want to sell full assemblies with bearing supports, flanges and end turning.
    We'll see what she gets back to me with without that stuff.
    Hoss
  12. #3392
    Mar 2005
    305
    The Ebay link shows more than 10 available. Got mine! My X needs it bad. Thanks Hoss.
    Sent from my DROID RAZR using Tapatalk 2
  13. #3393
    Sep 2006
    1738
    Hoss, you really put great info. Thanks!
  14. #3394
    Your welcome fellas.
    Hoss
  15. #3395
    Feb 2012
    296
    What size balls should be used with the linearmotions screws?
  16. #3396
    I haven't received the screw and nut from linearmotion yet to test, coming soon.
    Hoss
  17. #3397
    Dec 2009
    1416
    How much actual Y movement is everyone else getting? My PM-25 is giving me just a bit over 6.7" I'd like to get back to around 7" like it had when it was manual. Not sure if there would be an easy way to get that back.
  18. #3398
    Is your ballnut hitting some casting flash on the base? You should get the same travel as stock.
    Hoss
  19. #3399
    Dec 2009
    1416
    Not sure, it stops hard right there. The ballnut is facing forward... Pointing towards the front of the casting. I thought I had done it the other way around.
  20. #3400
    Facing forward is correct. The ballnut mount should still be able to hit the slot ends front and back just like stock.
    Maybe your 7 inch travel was without the Z bellows?
    Hoss
    Attached Thumbnails Attached Thumbnails 100_1630_800x600.jpg   100_2412y axis ballscrew installed_800x600.jpg
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
