587,300 active members*
3,466 visitors online*
Page 51 of 63 41495051525361
Results 1,001 to 1,020 of 1243
  1. #1001
    May 2010
    44
    Gotta be careful quoting these stupid spammers! Bille3 was promptly banned. :devious: (chair).
    Al.
    Thats what that was!
    Went right by me, why do they do it? Is there some benefit that comes of having a high post count? Whats the angle?
  2. #1002
    Dec 2003
    24223
    Who Knows?
    Often commercial links are embedded in the post.
    Al.
    Albert E.
  3. #1003
    May 2010
    44
    Found this bag of pre made perfect sensor housings at my local hardware shop, they even come complete with ideal little trigger magnets inside! I needed eight, there where eight in the bag. $8 later i was very pleased with myself.
  4. #1004
    Dec 2003
    24223
    They appear to be burglar alarm type? If so these are non-electronic and consist of reed switches operated by a P.M.
    They MAY not have the repeatable accuracy of the hall effect.
    Al.
    Albert E.
  5. #1005
    Jun 2011
    I think he plans to just use the magnets to trip the sensors
    Sent from my HTC VLE_U using Tapatalk 4
  6. #1006
    May 2010
    44
    Quote Originally Posted by NSR_CIVIC View Post
    Yep, exactly. These are just catches that grasp a plate, no electronics. The small plastic enclosure was all I wanted to house my electronics. The magnets are a cherry on the top.
  7. #1007
    Jan 2011
    14
    If your plan works... please post a picture of your end results; I am very curious if they would make the job harder or easier.
    My Problem is that I don't know how to change the files into G-Code just yet, and I am wait and watching this thread as this is an awesome thread I have read all of it and I have learned a lot.. but I am not sure how to put it all together. As my bob only has for terminals for switches and I don't know how I can get a CLOSED circuit for my EStop, and Three circuits for X,Y, and Z... Plus a Touch off Block for Z
    I am assuming that I have to wired Z as an Open circuit or something.. anyway, I am confusted and hoping someday this will make sense as now it seems like common knowledge to everyone but me.
    I also have a pile of 10-30 VOLT sensors with red lights that switch depending on if a reflector is near, but my BOB is FIVE VOLTS...
    Did I get the wrong BOB Break-Out-Board or am I missing something obvious... it is all a mistery to me and I just wait till I get some help.
    In the mean time I am using G-Wizard to practice G-Code enough to make G-Code for the switch mounts.
    One last thing, everyone just has 3/4 or 5/8 plastic that they just had lying around... well it isn't lying around here... where would one get a chunk for the cheapest price?
  8. #1008
    Jan 2012
    28
    Does anybody know how to set the retract after the switch has been activated. About half the time mine just stop and the switch remains activated. When it does this it stops and will not home the next axis.
  9. #1009
    35538
    Are you seeing an error message?
    And are the axis displaying as being homed?
    There is no retract distance. Mach3 retracts until the switch opens, then it stops.
    You might be seeing some "bouncing", where the switch is toggling back and forth a bit when retracting?
  10. #1010
    Jan 2012
    28
    home switches not working
    Thanks Gerry
    I have shielded cable with the shield grounded in the control box.
    I have one of those choke coils at the switch.
    I have a Y5U 104M capacitor from the 5v to ground. Without this it stops a lot on the way to home.
    I made the following measurements with auto zero off and jog set to 1.
    LED on = switch closed.
    DRO readings. 1.0222 led turns on. 1.0431 led turns off. This is very repeatable.
    I am homing at 20 speed.
    jog to led on then zero DRO. Somewhere around 1.0209 is switch off.
    DRO readings while homing from 2 inches. switch never opens after close led stays on.
    -1.209 -1.0052 -1.0130 -1.0156 +1.0104 -1.0235 -1.0026
    There are no error messages. Pressing "home" again gives the "fix the limit switch" error.
    If i change the homing speed to 1 then DRO value is more repeatable but the switch remains on. Any thing over 40 goes thru the switch and hits the rail.
    There is no bouncing usually it just stops dead.
    The axis is marked as homed, the "X" has the green halo around it.
    I have disconnected all but the X axis from the control panel and their switches.
    Jack
  11. #1011
    Jan 2012
    28
    I finally got it to work perfectly I will post a update after I get back from dinner
  12. #1012
    35538
    Is the switch also set up as a Limit switch, or a Home only?
    Does each axis' switch have it's own pin, or are they all sharing one pin?
    My guess is that the switch is opening enough for Mach3 to see it, but staying closed. Probably noise related, as you have so many things already trying to minimize the noise.
  13. #1013
    Jan 2012
    28
    Thanks Gerry
    It was electrical noise.
    Long story version follows
    when I attached the Hall first switch I connected it directly to the bob. Worked great. I was also looking at wiring solutions, in another thread. Attached is a mini din block I found and I thought using it would simplify the wiring of the other switches. Seemed straight forward.
    NEW CONCEPT INTRODUCTION SEEMED SMALL, NOT SO.
    The neat green and yellow terminal blocks are ground, we need ground, but they are grounded to the chassis(box,earth). So better check a little more. Ohm meter says case and 5v ground are common. OK then I rewire everything adding the two other homing switches. Seems to work but is unreliable as documented below,this thread.
    GIVE UP SEEK ADVICE, see below, this thread
    IT SHOULD WORK, even though I have received expert advice
    I DOCUMENT ALL THE THINGS THAT SHOULD MAKE IT WORK, see below,this thread
    REALLY GIVE UP, carefully read the expert advice for nugget of truth, you usually only need one to start with.
    ABSOLUTE STATEMENT FROM EXPERT, after the switch closes the motion will reverse until the switch opens. I am getting no or little reverse movement even though the switch is closed.
    Process of elimination.
    I disconnect the wire leading from the board to the terminal block, and to the switch so it is free. I click on home X, wait a moment, press the wire to the case. The motion stops no retrace. Since this is not according to the expert, but should work, I do this with variations for 30 minutes. Does not seem to work, well does not work.
    I disconnect the 5v gnd wire from the terminal block. I click on the home X, I touch the two wires, the ground and the home wire, together. Seems to be the same but I try again. After a few tries I can get the reverse motion to continue until the wires are separated.
    I rewire the terminal blocks using blocks isolated from the case(high voltage, earth).
    Works every time.
    Noise on the ground when the motor reverses direction, probably.
    Thanks Gerry(the expert)
    PS Yes I do have a college degree and yes it is in electrical engineering, solid state physics, doesn't help much when you are sure you are right
    Attachment 197426
  14. #1014
    Dec 2003
    24223
    One of the biggest problems IMO, is that Hobby machines have more or less settled on 5v I/O out on the machine, instead of going with what is pretty much the industry standard of 24vdc control.
    I follow this and and over the years have never had any problems that I see here almost every week!
    Al.
    Albert E.
  15. #1015
    Apr 2012
    230
    Quote Originally Posted by edoctoor View Post
    If you are looking for plastic, try Laird plastics Laird Plastics that's where I get mine min order is $40 but best prices and many different thickness and types
    http://youtu.be/9dTS1A2F4j8
  16. #1016
    Dec 2003
    24223
    In Canada there is also Johnston Plastics, I managed to get offcuts also.
    Al.
    Albert E.
  17. #1017
    Jan 2012
    28
    Al.
    Al
    Do you have some examples or suggestions about how to use 24 V input and output signals.
    It would seem that powering electronic switches with 24 V would be possible. If the inputs are just short to ground and held up by pull-up resistors Isn't the open circuit voltage still 5 V subject to the same noise problems.
    Outputs would seem to be more of a problem since they short when activated. Currently they short five bolts to ground to activate the device such as a switch. If you use 24 V that seems like that would be a problem.
    Thanks jack
  18. #1018
    Dec 2003
    24223
    Over the years I have used many custom built I/O boards, for Inputs, if something like the opto IC 4N25 is used close to the 5v port with 24v on the input side.
    For non-isolated outputs I have use 2n7000 for a small # or just a couple of outputs.
    If more is needed then I use the ULN2803 but these require some board level building with strip board.
    If you don't want to get into that, then I have used Opto22 products, these are boards that are made for mix and match I/O modules that translate from 5v-24v one side to 60VDC - 240AC, either way, in or out.
    If you search on Ebay for Opto22 you can see lots of it, you would need the 5v logic variety for PC port use.
    I have used common ground (mainly) and also Isolated commons with no problem with noise.
    Al.
    Albert E.
  19. #1019
    Jan 2011
    14
    Al.
    Thank you, I will call them.
    Al.
    I searched ULN2803
    http://www.digikey.ca/product-search...2803&x=16&y=15
    I was thinking that I would see Opto 5volt to 60volt... but it turns out that one requires more than a
    soldering gun and a oscilloscope to figure this stuff out.
    Thanks again... I don't quite understand,,, but I do appreciate a point in the right direction, I'll google for 5-60 Opto HACK or DIY later. As I have over $5000.00 worth of these sensors it will be worth it for me to find a solution.
    Many thanks, Edoctoor (backwords is Root Code)
  20. #1020
    Aug 2013
    8
  1. Replies: 3
    Last Post: 11-05-2013, 02:54 AM
  2. Home made electronic for Spindle control
    By dinko in forum CNC Machine Related Electronics
    Last Post: 05-31-2012, 02:52 PM
  3. Auto backlash sensing with electronic home switches!
    By RomanLini in forum Open Source CNC Machine Designs
    Last Post: 11-14-2011, 02:36 PM
  4. The relationship of limit switches to home switches.
    By MikeAber in forum CNC Machine Related Electronics
    Last Post: 11-04-2004, 08:28 PM
  5. Home made CNC mill (and some products made by it)
    By gcamlibel in forum DIY CNC Router Table Machines
    Last Post: 04-05-2004, 11:54 PM
