587,997 active members*
1,334 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > CNC Project !! AMA25LV (G0704) Mill !!!!!!!
Page 23 of 28 132122232425
Results 441 to 460 of 552
  1. #441
    Sep 2014
    286
    Re: CNC Project !! AMA25LV (G0704) Mill !!!!!!!
    Also the tool rack I made does the job perfectly
  2. #442
    Sep 2014
    286
    Ok some major progress today,
    I received the Belt drive kit and fitted on the machine and immediately noticed I had a issue ! The hole for the wire to go down is now blocked so I will have to drill a new one, the sensor is also too low so will have to pack that up.
    Also I don't know how tight I should have the belt. I did it really damn tight and the top bearing sounded odd, rattle at low rpm. Not tight enough and the torque is very very little at low rpm.
    Also the motor now arks massively and at full RPM I heard a pop and the motor blew the electric in the garage haha no damage but I suppose It will have to bed in the new brushes.
    Attachment 277008Attachment 277010Attachment 277012Click image for larger version.
  3. #443
    Aug 2010
    630
    Quote Originally Posted by onocyclone View Post
    I wouldn't bother with drilling the hole. Chances are your going to remove the control box and use cable chain.. in which case, the wire will route differently.
    Inner Vision Development Corp. - http://www.ivdc.com
    Website Design & Development. Shopping Carts, SEO and more!
  4. #444
    Dec 2012
    390
    It looks like you have the sensor upside down compared to the picture in the eBay listing for the belt drive kit.
  5. #445
    Sep 2014
    286
    No it's not of eBay, it is the correct way up too ill have to pack it up later
  6. #446
    Dec 2012
    390
    It looks very much the same as this kit and in picture 2 you can see the sensor is upside down compared to your picture.
  7. #447
    Sep 2014
    286
    Yes that's the kit and it does look like my sensor is upside down, I'll have a look at that, cheers.
  8. #448
    Sep 2014
    286
    Today I turned the sensor round and it fits perfectly now, I need to rout the wire for it some how
    I've found something quite worrying though, when I pull the belt to the specified tension then the top bearing makes a real noise ! I have to put little tension on the belt and it doesn't happen. I machined some plastic with some large depth cuts and it didn't stop or slip.
    Also the motor when it gets near full rpm it arks out and trips the electrics in the garage. Every time. Not sure if the motor is scrap. The commutator looked fine when it was dissembles and cleaned.
  9. #449
    Nov 2009
    4415
    I have a different belt drive but I do run various tensions. Different speeds seem to need different tensions in my experience.
    A lazy man does it twice.
  10. #450
    Sep 2014
    286
    What about the bearing noise like I described, have you encountered this ?
  11. #451
    Sep 2010
    717
    What kind of bearings does it have?
    Current build: http://www.cnczone.com/forums/diy-cnc-router-table-machines/264838-new-machine-desing-quot-cnm13-quot.html
  12. #452
    Sep 2014
    286
    Stock bearings, it is the top bearing without a doubt.
  13. #453
    Sep 2010
    717
    I'm not familiar with the machine, Angular contact bearings? Or?
  14. #454
    Sep 2014
    286
    Sealed ball bearing
  15. #455
    Sep 2010
    717
    The bearing must be worn out if there's noise (Or it's running past it's max RPM). An AC bearing would be better than a plain ball bearing. The Z axis needs to take loads from sides and up/down.
  16. #456
    Dec 2010
    55
    You can get a lot of "rattle" from the quill drive splines. Stock bearings with the rubber seals are very high friction (prime cause of the arcing) - the metal shield equivalents are much freer moving.
    http://www.hmsnz.co.nz
  17. #457
    Nov 2009
    4415
    If that was to me, no noise from the bearings in my case.
  18. #458
    Dec 2012
    390
    Quote Originally Posted by Flexo! View Post
    Somewhere in either Hoss' thread or mhackney's(?) thread there is a dxf for a spacer for the quill drive to stop it from rattling.
  19. #459
    Sep 2014
    286
    Now you mention it it could be the quill. It would take some serious grief to damage the top bearing! It's huge,
    Where does this spacer fit to stop the rattle ?
    Also I machined some test pieces out of plastic today and the accuracy of the mill is pretty good now
    Between 0.00-0.05mm even on Diameters. I may have to slow the compensation Dow a little because it changes direction quite quickly still. But it is much much better than it was before
    Attachment 277144Attachment 277146Click image for larger version.
ID:	277148Click image for larger version.
  20. #460
    Dec 2012
    390
    If you search for a thread by mhackney called "building a big brother for my X2" or something similar you will find where it goes. Basically on top of the spindle, around the splines. You can get a.stl for it there or in this thread
  1. Yay! "Project Cecil" G0704 build has begun!
    By TroyO in forum Benchtop Machines
    Last Post: 03-31-2015, 09:29 PM
  2. Let's call this the Turnkey Project - G0704
    By bogiestl in forum Benchtop Machines
    Last Post: 01-30-2012, 08:11 AM
  3. g0704 - conversion project
    By dsdmax in forum Benchtop Machines
    Last Post: 03-02-2011, 04:03 AM
  4. g0704 - first mill - questions ....
    Last Post: 03-28-2010, 09:32 PM
  5. CNC milling machine project, Weiss WMD25 / Amadeal AMA25LV
    By carl0s in forum Uncategorised MetalWorking Machines
    Last Post: 02-20-2010, 12:47 AM
