587,613 active members*
3,667 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang Chinese VFD settings and manual here!
Page 6 of 41 4567816
Results 101 to 120 of 808
  1. #101
    Jan 2015
    35
    Re: Huanyang Chinese VFD settings and manual here!
    Any insight on my issue? Please see the video.
    Mach 3 and Chinese spindle / vfd discrepancy: https://youtu.be/D6a2j833OgM
    Sent from my SAMSUNG-SM-N910A using Tapatalk
  2. #102
    15362
    discojon
    Have you checked to see if you are getting 10v out from your breakout board, at full speed, you need to have 10v to reach full speed
    Mactec54
  3. #103
    Jan 2015
    35
    discojon
    Have you checked to see if you are getting 10v out from your breakout board, at full speed, you need to get 10v to reach full speed
    I have and I'm not. I have replaced the breakout board also and it didn't help at all. When full speed is requested in mach, only about 9v gets output from ESS.
  4. #104
    Apr 2013
    35
    I have just installed a Huanyang VFD on my drilling machine so that I can get variable speed without having to open the cover and change belts. I had some previous experience in setting up VFD's when I installed Invertek drives on my two milling machines. The Invertek drives are very high quality and more expensive than the Chinese drives however they have one feature that I really like. They are completely silent when idle. They have cooling fans but these don't power up until the drive has been operating for a while. The Huanyang drive I just installed runs the cooling fan continuously and I find it a bit annoying. The thing with a drilling machine is that I might only use it for a few minutes at a time and it can remain idle for long periods. It is a nuisance to have to switch the drive on at the mains each time I want to use the drill and it takes 10 seconds or so for it to boot up. Does anyone know if there is a setting or a tweak to make the fan switch off when the drive is idle?
    Any help would be appreciated.
    Regards,
    Preso
  5. #105
    May 2003
    132
    You can add a switch to the drive along with a pot to control speed.
    Don
  6. #106
    Apr 2013
    35
    I guess I was hoping that there was a setting that allowed the fan to switch off unless the temperature of the heatsink rose above a certain level. On another matter..... I have fitted a potentiometer and a remote switch to control the frequency and start/stop of the drill machine motor. My problem is that the pot runs the motor up to max frequency over a little more than half the full rotation of the pot. In other words, I can control the speed up to half way and the remaining half rotation does nothing. I want to calibrate the rotation of the pot and laser etch a scale to show RPM but I am puzzled why I cannot get a full scale. I have measured the voltage at the centre pin of the pot and it runs from zero volts to 10 volts over the full rotation of the wiper. The inverter seems to want to run at max frequency with a little over five volts. Can anyone shed some light on what I might be missing.
    Regards,
    Preso
  7. #107
    May 2003
    132
    You just need the correct pot.
    Don
  8. #108
    15362
    Quote Originally Posted by Preso View Post
    Regards,
    Preso
    You could use the vfd drive relay to turn the fan on/off you would have to rewire it, so when you turn your drill spindle on the relay will close & run the fan, just make sure the VFD does not overheat when the fan is not running
    Two things that you may not have right with your remote control, you need a 10K pot, or you may have it wired incorrectly
    You also need to set Parameter PD070=0 & PD072 to your max frequency you are using
    Mactec54
  9. #109
    Apr 2013
    35
    Success! Thanks Mactec54. I did have a 10K pot but I had the PD072 set to 400hz. instead of 100 which was my max frequency. Now I get speed control over the full range of the pot rotation. Do you think the drive would generate any heat if it was idle?
    Regards,
    Preso
  10. #110
    15362
    Regards,
    Preso
    There will be some, but should be very small amount, the fan should really run for at least 30sec after the spindle motor has stopped, this would be my only concern, as there will be heat in other areas that need the fan to cool those parts, I will check to see if this is possible to do & have a time delay for the fan, these drives don't have a strong IGBT which if over heated they will fry
    Mactec54
  11. #111
    Sep 2015
    Please may I ask if someone could take a quick picture to show me what terminals on the vfd I should wire to my BOB?
  12. #112
    Sep 2015
    5
    PLEASE HELP!
    (new to the forum)
    I have a Hitachi 3ph 1.5kw wood lathe- came with a Hitachi inverter, which I dropped and broke (insult to injury it was brand new I left it in storage!)
    so... I bought a Huanyang VFD 1.5kw and can't get it to do anything except to START to turn the spindle, the VFD continues to spin up but the motor doesn't. I am totally new to all this, I have been trying for weeks now to get it working leaving me more and more frustrated! I reset the the pd013 to 08, changed the pd03-05 to 400, checked the start seconds at 10, and brake to 15 seconds. nothing has changed anything?
    Please forgive my ignorance- I'm just a woodworker/artist-
    I hope its something super simple- the manual is written by engineers (no offense, but enough said)
    Thanks!
  13. #113
    15362
    Quote Originally Posted by GunShow View Post
    PLEASE HELP!
    (new to the forum)
    Thanks!
    Sounds like you don't have the correct parameters set,but don't keep trying to run it or something may smoke, your drive is most likely to small for your spindle, you should of had the 2,2Kw VFD, it may last if you get the parameters set correctly
    Is your spindle 300 Hz or 400 Hz, you have to know this, if it is 400 Hz then go to post 32 and set the parameters, the same as what is in the post, you will have to do a reset first
    Mactec54
  14. #114
    Sep 2015
    5
    The spindle/motor is a
    Toshiba 2hp 1.5 kW 230v 5.6 amps
    60hz
    Not sure how to figure MHz?
    The Toshiba unit that I dropped and broke was oem from lathe manufacturer. Same parameters as HY
    Now I swapped the 1hp inverter off another lathe and it ran up to speed fine (no cutting load) I don't understand these things at all I guess?!?
    Please help! I have to get this lathe up and running asap.
    Thanks!
    Alex
  15. #115
    Sep 2015
    5
    60hz
    Thanks!
    Alex
    Maybe someone can help me with the proper setup sequence to a complete novice? I would be super grateful!!
  16. #116
    15362
    60hz
    Thanks!
    Alex
    Well you should've given those details from the start, your motor is just a regular AC motor it is not a spindle motor, Do a reset on the drive, & most likely the VFD Drive defaults, will get you running, you will have to set the Volts/ amps/ 4 Pole & motor speed this number will be on the name plate of the motor, take a photo & post it here
    Don't run the 1 Hp VFD with your 2 Hp motor you will burn it out the VFD Drive in no time
    You can't use the settings in post 32 that I said you could that is for a High speed spindle, yours is not
    You may have already damaged the VFD that you have with having the wrong parameters set, you will have to tell us a lot more now, if we are going to get you going, Photos will help
    The highest Hz setting you can use with that motor is only 100Hz to 120 Hz Max
    Mactec54
  17. #117
    Sep 2015
    5
    hope this is good enough, the board had a hard time uploading anything bigger
  18. #118
    15362
    GunShow
    Here is what your settings need to be, no other setting should be changed
    Huanyang Mactec54
    PD000=0 for Parameter unlock ( 1 ) for Parameter Lock ( Must be 0 to do a Reset )
    PD001=0 (1 For Remote Control)
    PD002=0
    PD003=120
    PD004=120
    PD005=120
    PD007=20
    PD008=220
    PD009=15
    PD010=8
    PD011=50 (Minimum Setting 50)
    PD13= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
    PD014 Accel=15 ( Adjust to suit)
    PD015 Deccl=15 (Adjust to suit)
    PD141=220 ( Motor Rated Voltage )
    PD142=5.6 ( Motor Max Amps)
    PD143=4 ( Motor Number of Poles)
    PD144=2400 (Max Motor RPM)
    For Remote Pot use
    PD002=1
    PD70=0
    PD72=120
    PD73=50
    Mactec54
  19. #119
    Sep 2015
    5
    [QUOTE=mactec54;1768524]GunShow
    Huanyang Mactec54
    THANK YOU
    A MiLiLoN ThAnK YoUs!!!!
    It works great
    PD002=0
    PD003=120
    PD004=120
    PD005=120
    PD007=20
    PD008=220
    PD009=15
    PD010=8
    For Remote Pot use
    PD002=1
    PD70=0
    PD72=120
    It works great
  20. #120
    Nov 2015
    4
    I'm trying to use a Huanyang Chinese VFD to plug a Brother MD-813 on a single-plase installation ...I should have make some misconfigurations because the motor doesn't start.
    The specs of this servmotor are here : https://www.google.fr/url?sa=t&rct=j...,d.d2s&cad=rja
    Can someone tell me how to configure the VFD to make my motor work fine ?
    Thanks a lot, I'm such in a mess with this...
  1. Replies: 6
    Last Post: 05-04-2024, 04:05 PM
  2. Car hoist 3phase settings on huanyang vfd
    By pietskiet in forum Spindles / VFD
    Last Post: 10-21-2019, 10:04 AM
  3. Huanyang SL-240EE Manual (SL Series Manual for Vector VFD)
    By Cogolith in forum Phase Converters
    Last Post: 05-24-2016, 04:19 AM
  4. Huanyang inverter PD settings
    By jamriggsy in forum Phase Converters
    Last Post: 03-15-2013, 04:54 PM
  5. Huanyang 2.2kw VFD, 0-10v 3600rpm settings?
    By EmeraldIsleforg in forum Phase Converters
    Last Post: 09-23-2012, 03:00 PM
