603,330 active members*
3,109 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Importance of ball screw pitch size
Results 1 to 20 of 29
    35494
    Re: Importance of ball screw pitch size
    So an increase in dia, and/or a decrease in pitch will result in less effort required.
    But an increase in diameter increases inertia, which can require more effort to get it turning.
    Mar 2017
    927
    Do you think I should buy a larger motor for my long axis then (the one that has the larger diameter screw)? I currently have the 381oz "low inductance" motors that many here start with.
    looking at the specs for these motors, they seem to have a decent amount of torque and peak torque for the job but i'm not really sure how much torque is optimal for this purpose. My inclination is to wait and see how well these motors cope before deciding to upgrade or not but.... if I am going to need to invest in new motor mounts and motor couplings plus redesigning the axis to make them fit, it would be easier to do that now if you think I'm likely to need more juice?
    If I can do what I need with the 381oz motors then I would prefer to wait until I am ready to upgrade to a decent servo set-up.
  1. Ball screw size and pitch
    By Slink76 in forum Linear and Rotary Motion
    Last Post: 09-09-2017, 06:32 AM
  2. Lead vs Pitch of ball screw
    By mit_ball_screw in forum Linear and Rotary Motion
    Last Post: 02-26-2016, 09:13 AM
  3. Ball screw size/pitch?
    By jakk100 in forum DIY CNC Router Table Machines
    Last Post: 01-09-2016, 04:41 PM
  4. ball screw pitch nema23 320 oz
    By paerre89 in forum DIY CNC Router Table Machines
    Last Post: 09-28-2014, 10:44 PM
  5. What speed and pitch ball screw
    By Georgie in forum Benchtop Machines
    Last Post: 01-08-2006, 07:14 PM
