588,225 active members*
4,826 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > v26 plunge point lead in location...how to change?
Page 1 of 3 123
Results 1 to 20 of 48
    Oct 2007
    446
    Question v26 plunge point lead in location...how to change?
    right now my lead in is at a corner and i want it in the middle of a spline....i set my default chain start point in the middle. When i try and set my plunge point it say select start point on geometry. right click ok. I shift click my spline, select the middle point and it just seems to deselect that spline..nothing showing as selected. recomputing doesn't change lead in location....
    ideas?help?
    thx
    Dec 2008
    4548
    Quote Originally Posted by airbrush View Post
    ideas?help?
    thx
    What if you put an actual point there? The "control point" of a spline arent actual points.
    Oct 2007
    446
    Re: v26 plunge point lead in location...how to change?
    will try that...just seems odd...i can select my default start location the same way no problem...I would have assumed the lead in would just adopt that..?
    I am doing a simple pocket rough routine if that helps at all?
    Can you tell me your workflow for setting your lead in location? I've never tried adjusting before..just took the default but this time i really do want in a different location if i can....
    Dec 2008
    4548
    I dont have my computer to help out.
    But v26 is pretty old. And i do know some ops like pocket didnt have control if where the pocket plunges....
    But i cant help direct right now.
    ideas?help?
    thx
    Split the spline, it's choosing the start of the element in the geometry that you select, not your chosen point in that element.
    Oct 2007
    446
    will give it a try an lunch hour ...can only run demo here at work though....seems strange that it wouldn't default to your desired start location...just my two cents
    Oct 2007
    446
    I tried...I can never get the location to change...i can change my default chain start point no problem...but cant change where plunge point or lead in starts...
    v26 pocket op
    Jun 2008
    1838
    Seems to work fine here on my V26 Build 1335 on normal pocketing, the exception is when "Advanced" pocketing is used, the adaptive toolpath has to set it`s own plunge point from what I can see, that doesn`t work here
    Zig Zag, Pocket In and Pocket Out will let me change the plunge point to anywhere I drop a point into the drawing
    Hope that`s of some help for you
    Regards
    Rob
    Oct 2007
    446
    What do you mean by drop a point? And how do you select a different spot?? By plunge point?...if I select plunge point and reselect click a line or point...its like it just deselect everything...nothing showing a picked point like when you do default start point....
    Quote Originally Posted by The Engine Guy View Post
    Regards
    Rob
    Jun 2008
    1838
    Attached is a simple pocket file, using the default "Pocket Out" pattern.
    I drew the pocket shape and then the stock square, then I put the spline across the pocket shape, next I went to "Point > On Entity > 50% >" now I went to the spline and just Left Clicked anywhere on the spline and the point appeared exactly on the centre of the spline. You can use the "Utilities > Break" facility to break the spline into as many pieces as you want and then either place a point at the end or anywhere along the spline using the "Point > On Entity" facility using the Percentage, Distance or Angle options to get a point where you want it.
    I then created the Pocket toolpath and let it do it`s default toolpath without setting a plunge point, I also used the Sketch option to just create a couple of other points in random locations, now I went to the Plunge Point in the Tree and righ clicked on it and then on "Re/Select", next I left clicked on the point I had placed on the spline and then went back to "Pocket" in the tree and did a "Compute Toolpath" and the plunge point moved to the point I had selected on the spline.
    I did the same procedure with the two random points I had placed (Dropped) into the pocket and each time the plunge point moved to the selected point
    A little bit of work but fairly easy as it turn out, have a go with the file I have attached, it works fine here, just play around with it till you have got the hang of it, just remember that if you want to use the "Advanced" pocketing option it doesn`t work
    Hope that`s a bit clearer for you
    Regards
    Rob
    Attached Files Attached Files
    Dec 2008
    4548
    Quote Originally Posted by BurrMan View Post
    Shift clicking a spline shows its "control points" for editing the spline.
    Create an actual point.
    Oct 2007
    446
    great..thx for the help...will take a look at lunch hour....so you acutally have to 'place a point' ..i assume it would just use the existing geometry you have...for example, reselct plunge point - select spline, shift select to bring up the "points" there and left click select one....
    will give it a whirl...
    Oct 2007
    446
    right...to me i would assume the software would be able to use those as well to define plunge point...since i can use those to define default start location....its inconsistent usage....another quirk...
    Jun 2008
    1838
    Yep, just follow the Burrman, you won`t go far wrong with his advice
    Regards
    Rob
    Oct 2007
    446
    Ok..its kinda works...but its not exactly what i'm looking for....the plunge point changes...but now...how do i change where the actual cutting starts? If I want it to start in the middle..how to??
    And how do i change the direction of the Lead In to go the other way??
    Attachment 389678
    Jun 2008
    1838
    Not sure just what you are asking now, the Plunge lead in will start cutting from the point you have selected, if you use either the Ramp or the Spiral lead in option then the cutter will either ramp or spiral to the point you set for the Plunge Point and then start cutting in X and Y axis from that point.
    So the point selected is the actual depth set for cutting, to get the tool to run in a different direction then in the Ramp option choose either the Climb Mill or the Conventional Mill to change direction, in the Spiral option changes from CW to CCW will change the direction in that mode
    Up to you to find the right Ramp length and angle and spiral radius and angle to get the desired result, you will just have to experiment with the different options
    Regards
    Rob
    Oct 2007
    446
    Yes, so I would like the actually start cut point to be in the middle..right now its at the end of the spline, how do i change that?... and the ramp in to that mid point...it is cutting in the direction I want...but ramp in goes the opposite direction of my cutting direction...I want to ramp in, in the direction of my cutting direction...right now the ramp in always backtracks..can i change that and can i change where my cutting point starts??
    I can't seem to make it do that? or I don't know how yet...
    Jun 2008
    1838
    OK, try the attached file, I have done a simple spiral leadin in a way that actually starts the entry at pretty much the point set for the plunge and by using the radius value and the angle value to get the cutter to spiral down to the Plunge point and then set off at the set DOC
    If you want it to go in the opposite direction then just change the CW/CCW setting in the Spiral Leadin
    Is this more what you are trying to achieve ? ?
    Regards
    Rob
    Oct 2007
    446
    nope...
    I'm doing a cut in...I want the start cutting location to be in the middle of that spline and I want to ramp in, in the direction of cut....
    At work just running in demo mode...so cant save a file to share...
    Jun 2008
    1838
    It doesn`t appear to be possible to do what you want as the Ramp function will always ramp into the material and then when it reaches the DOC point it turns back on itself and then turns again to go in the original direction of the ramp for the remainder of the pocket cutting.
    The "Finish Profile" will ramp down and then continue in the same direction.
    Anyway, thats the best I have for now, hopefully someone more knowledgable than I (Nick,Burr,James??) will jump in and finish it off as I am now probably not "seeing the wood for the trees"
    See attached file for a "nearly" solution
    Regards
    Rob
Page 1 of 3 123
  1. Selecting Start Point for Plunge Roughing - V28
    By geoffw in forum BobCad-Cam
    Last Post: 01-11-2016, 03:59 AM
  2. Help changing plunge and retract location
    By SWATH in forum Visual Mill
    Last Post: 01-06-2011, 10:22 PM
  3. Replies: 3
    Last Post: 10-30-2010, 04:31 AM
  4. need drill cycle to post every point location.
    By kesparate in forum Post Processors for MC
    Last Post: 03-11-2009, 04:40 PM
  5. Chaining from specific start point for plunge
    By jrrhotrod in forum Mastercam
    Last Post: 04-19-2008, 07:46 PM
