Quote Originally Posted by Sam_Beckham View Post
That would be an easy enough fix for sure. I'll try that out this afternoon.
Does it cause any issues with the machine loosing position if it's interrupted during a run? That was the only reason I had them separate previously. I've never run a CNC mill before though, so maybe it's a non-issue.
Try not to cycle any system On / Off to often, logic power should be on before the main supply this is, this is norm with all Servo Drives and should not be cut with the main contactor for the drive
