588,152 active members*
5,042 visitors online*
Results 1 to 13 of 13
    Dec 2003
    24220
    Panel Paint Help Needed
    OK, I need help from someone who has used or have explicit info. on the following panel paint for LCD bezels I have a need for.
    I have just about exhausted all my resources in trying to find a Crackle or crinkle style of paint or method of producing, I do not mean the crackle as it now applies to the anitique look for furniture etc. but the kind of finish that has been around for decades on (older) electronic test equipment and camera equipment. I have come across sites that refer to Krylon etc, but the Krylon site does not mention it. I have a large local paint distributor/supplier selection, but none of them know of or carry anything like it, its frustrating because I know its out there as I have purchased modern panels with this finish. Help, anyone?
    Al
    Albert E.
    927
    Al,
    VHT wrinkle paint
    http://www.jegs.com/cgi-bin/ncommerc...99&prmenbr=361
    Most automotive speed shops carry the stuff.. Trick: use a heat gun to speed up the wrinkle process and make the wrinkles deeper.
    Dec 2003
    24220
    Thanks .. that looks promising, but I can't seem to find the VHT web site to see if I can get it in Canada?
    Al
    Albert E.
    May 2004
    600
    You can get it in Australia and I've also seen it here in Belgium so getting in Canada shouldn't be a problem.
    Sep 2003
    1113
    Al_The_Man -
    You can also look for "Truck Bed Liner" Paint. It has a textured finish - not too unlike wrinkle finishes. I find its application a bit easier - one coat and you've pretty much got the effect. The wrinkle paints I've tried tend to require several (like 3) coats, specific drying times and sometimes the subtile application of heat. I say that having melted a project trying to get the paint right - DOOOH!
    Check the autoparts stores, KMart-like outlets, etc.
    ADDED: PlastiKote Black 217 is the one I didn't succed with. www.plastikote.com if you're interested in that one.
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    May 2003
    130
    What are the bezels made of?
    Dec 2003
    24220
    1/8" Aluminum .
    Al
    Albert E.
    927
    May 2003
    130
    Contact your local powder coater, this finish can easily be duplicated and will be far stronger than spray paint.
    Jul 2003
    125
    Jun 2004
    9
    Talking
    Quote Originally Posted by Al_The_Man
    Al
    Local Body shop supply stores, ask for SEM products, check their web site at;
    http://www.sem.ws
    Specifically what you are looking for, check the following PDF document in section "V"
    The product 39853 (Spray Can) 39854 (Quarts) is a Texture Coating that can receive a colour topcoat sold separatly.
    Best regards from Montreal
    frenchnew
    Still learning something new.
    Apr 2003
    470
    They have it at http://www.tubesandmore.com/ but can't ship to Canada...
    Try other places for Radio Restoration. Body shop supply, I hear Princess Auto has about everything up there in Canada... did you look there...
    Nathan
    Dec 2003
    24220
    Thanks to all the leads, I should be able to get at least one of them that will give me the result I want.
    Al
    Albert E.
  1. Coolant eating my paint.
    By nervis1 in forum Uncategorised MetalWorking Machines
    Last Post: 12-05-2007, 10:27 PM
  2. Panel Saw type CNC?
    By Edh in forum DIY CNC Router Table Machines
    Last Post: 05-30-2005, 03:05 PM
  3. What's needed for complete setup?
    By LeeWay in forum Gecko Drives
    Last Post: 03-09-2005, 03:38 PM
  4. CNC Operator Panel Design
    By Al_The_Man in forum DIY CNC Router Table Machines
    Last Post: 09-13-2004, 06:03 PM
  5. Can a wood router make paint stencils?
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 05-10-2004, 06:46 AM
