603,850 active members*
5,419 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > What's needed for complete setup?
    Jun 2004
    6618
    I was wondering what is needed for a complete Gecko setup. I noticed in the manual that other things are needed. What might these be? Where might I locate them?
    The problem- I was testing the motors last night and we neglected to cap all the center wires from my motors. My contoller was a Xylotex 3 axis drive.
    One of the motor wires shorted out on my controller case and smoked the Xylotex. Anyway, a fuse may have prevented this mishap, but the manual says not to put fuses on the system.
    At any rate, I understand that I can get this board repaired possibly.
    I am wondering if it might be btter to go with a Gecko system, but need to know what a system involves cost wise.
    My motors are 2.8 amp at bipolar, which is a little too high for the Xylo. Should I spend my money on a second Xylo as a backup or go with Gecko? Help me choose please.
    Lee
    Mar 2003
    35494
    This might not help with your decision, but the Gecko most likely would have smoked as well.
    You'll need three Geckos, preferably a breakout board and most likely a new power supply. If your going to get Geckos, use a higher voltage supply to take better advantage of them. Without a higher voltage supply, the performance increase would be very small.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Turbo CNC Not Running.... Setup?
    By Davedbq in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-04-2005, 08:20 PM
  2. Boss 5 help needed
    By rsr911 in forum Bridgeport / Hardinge Mills
    Last Post: 10-27-2004, 06:10 AM
  3. Setup instruction
    By dgb in forum Uncategorised MetalWorking Machines
    Last Post: 09-07-2004, 12:39 AM
  4. Taig CNC ready setup help??
    By efreak in forum Taig Mills / Lathes
    Last Post: 08-25-2004, 01:30 AM
  5. How to change the setup sheet format?
    By cwww in forum Uncategorised CAM Discussion
    Last Post: 06-30-2004, 08:28 PM
