587,702 active members*
3,284 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Wishlist for the next drive (describe your dream drive!)
Page 7 of 11 56789
Results 121 to 140 of 205
  1. #121
    Sep 2004
    1207
    Final board high power testing is going well. I'm running it at 14A continuous and it's not overheating without additional heatsinking (but fan cooled though). 14A produces 100% more heat than 10A since resistive losses raise in power of two.
  2. #122
    Sep 2004
    1207
    I think I have discovered an way to extract even more incredible speeds from stepping motor (in servo mode). I just broke my previous record (3300 rpm at 30Vdc) and my ears. Now the same setup goes up to 6000 rpm!
    I was able to turn same motor only little over 1000 rpm in traditional open loop mode before stalling.
  3. #123
    Jun 2003
    125
    6000rpm!!! The commutation frequency is approaching PWM frequency no?
  4. #124
    Sep 2004
    1207
    I did some code changes again and now I reached 6975 rpm... it will take time before the firmware can take control of this in normal operation. Now it is based just on a testing code.
    7krpm means 5833 Hz commutation frequency while PWM frequency is 20 kHz. Theoretical upper limit for commutation would be 10 kHz.
  5. #125
    Sep 2005
    1660
    Tero, can you explain to me a couple things. You mentioned a stepper [above] in 'servo' mode.. what are the results of running a stepper in 'servo' mode. Does it produce the rated torque all the way up the rpm scale like a servo or? At 6kpm, what torque would you be delivering compared to the name plate torque?
    Also, will the VSD-A do this as well?
    Thanks sir
    J
    JerryFlyGuy
    The more I know... the more I realize I don't
  6. #126
    Sep 2004
    1207
    Jerry,
    Maximum obtainable torque does not increase in servo mode, it is just unstallable and reduces heating. So torque reduces when running fast. However, higher peak torque can be get at low speeds because cooler operation allows overloading just like servos.
    VSD-A hardware is not very optimal for steppers which is why such stepper support is not available.
  7. #127
    Aug 2007
    558
    Hey,
    Any hint as to final price yet? I'm saving up...
    I like the idea of the limit switches going to the VSD not the BOB. Does the VSD have opto isolators - could I do away with the BOB altogether? Now that idea I like
    Regards,
    Jason
  8. #128
    Sep 2004
    1207
    Final price will be similar to VSD-A but exact price is still undetermined.
    I just got good news from factory. The first production batch is being manufactured while I type this. :-)
  9. #129
    Apr 2005
    124
    I always wondered why no one made a multi phase drive for steppers. They just seemed like the natural progression.
  10. #130
    Aug 2007
    558
    Quote Originally Posted by Xerxes View Post
    Good news!
    ...can't wait Say the word, I'll send you my money!
    Jason
  11. #131
    Sep 2004
    1207
    I got a message that first 125 units are on the way to us! :-)
    I have an USA visit on week 38 that may delay little bit the beginning of sales. If tuning software is ready when I return, the sales can begin immediately. Timo is developing GDtool so the rest is in his hands.
    At the point of release, the stepper support will be operating at limited speed. High speed stepper operation needs more work and will be available as downloadable free firmware upgrade when it's ready.
    This is how final VSD-E looks like (the one with grey anodized plate). It looks better than prototypes because pin headers are not angled and reaching over board edge. I also milled a prototype of high power heatsink. It is uncertain whether or not it becomes available as an option (depends on cost).
  12. #132
    Jun 2003
    125
    Man, that heatsink design is very sexy. I have a question about using higher voltages with this drive. Is it a matter of replacing a few resistors, and the FET's??? If it is...maybe you could make a few drives with those parts not installed...and sell it as a partial kit. Just an idea for those of us running over 100V.
  13. #133
    Sep 2004
    1207
    CNCaddict, half assembled drive would probably cost more than fully assembled since it would take more production steps to prevent solder getting into empty component places (two new steps, one for reflow and one for wavesoldering). Also giving warranty for such product would be complicated.
  14. #134
    Sep 2004
    1207
    Things with VSD-E are a bit late but we are doing great progress. Sales begin in matter of days.
    From this site you can see how VSD-E is meant to be installed:
    http://granitedevices.fi/index.php?q=vsd-e-install
  15. #135
    Sep 2005
    1660
    Ok Tero.. now I'm gonna bug ya.. are you going to sell the fibre optic cables seperate for us VSD-A users? I've been looking for a reasonable solution to seeing the error state on my drives [which are tucked up in a sealed console/cabinet] but haven't found anything which is reasonably priced and simple to aquire..
    I REALLY WANT SOME!
    Can I buy a set [or four]
    J [finger's poised to log into Paypal and send money]..
    JerryFlyGuy
  16. #136
    Sep 2004
    1207
    Hi Jerry,
    The plastic core fibers are available in many electronic part distributors such as Newark or Farnell.
  17. #137
    Sep 2005
    1660
    Hrm.. I must be searching for the wrong thing.. you have a Newark part number?
    J
    JerryFlyGuy
  18. #138
    Sep 2004
    1207
    This seems to be similar that I used:
    Newark Part Number: 16F3288
    Strange that Farnell seems to have much better selection on these. Usually it's otherwise around.
  19. #139
    Aug 2007
    558
    That's great news, and good timing for me - the new machine is almost ready for them. I can't wait!
    The installation looks good - almost too simple Is there a price/detail on the installation kit yet?
    Best regards,
    Jason
  20. #140
    Sep 2004
    1207
    Jason,
    Installation kit price should not be much higher than same parts separately from any parts distributor (haven't calculated cost yet). Kit is meant only to reduce part hunting. It includes at least connectors, fibers and installation panel.
Page 7 of 11 56789
  1. Direct Drive Vs Belt Drive for a Mill/Drill Retrofit?
    By pfeist in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2012, 09:12 AM
  2. KTK Drive
    By GarageShop in forum Bridgeport / Hardinge Mills
    Last Post: 09-01-2006, 02:43 PM
  3. can brushless drive drive brushed motors ?
    By max_imum2000 in forum Servo Motors / Drives
    Last Post: 02-09-2006, 02:35 PM
  4. Concerning the Drive Box
    By Gorillakilla in forum Xylotex
    Last Post: 12-04-2005, 02:37 PM
  5. which VFD drive
    By Karl_T in forum Uncategorised MetalWorking Machines
    Last Post: 12-03-2005, 11:17 PM
