603,796 active members*
4,005 visitors online*
Results 1 to 20 of 34
Threaded View
    Sep 2003
    1490
    Question Homing and Limits Setup
    Homing and Limits have been set and when I press Reference all Home everything goes home just fine in the picture on the machine. It is a fixed gantry so I wanted home to be in the X-, and Y+ and Z+, this way it would be the easiest to load and remove work.
    When the machine has been homed and Soft Limits is activated I can drive the X in the plus direction and the Z in the minus direction, however I cannot move the Y in the minus direction. The only way I can move the Y in the minus direction is to disable the Soft Limits.
    I have attached a screen shot of the Homing and Limits setup screen showing the settings; hopefully this will show where the problem is.
    Attached Thumbnails Attached Thumbnails DSCN2770.jpg   DSCN2771.jpg   DSCN2773.jpg
  1. How homing and limits work
    By SyilAmerica in forum Syil Products
    Last Post: 11-14-2007, 08:55 AM
  2. How to setup homing in Syil X3
    By albatros62 in forum Syil Products
    Last Post: 11-11-2007, 07:14 AM
  3. Help with limits not working when homing
    By dave70 in forum Mach Mill
    Last Post: 03-22-2007, 05:46 PM
  4. New setup with Mach3 - Limits work, homing doesn't
    By journeyonline in forum Mach Software (ArtSoft software)
    Last Post: 03-22-2007, 03:09 AM
  5. Limits, homing, and relay switches
    By Bloy2004 in forum CNC Machine Related Electronics
    Last Post: 11-25-2003, 12:17 AM
