587,842 active members*
3,413 visitors online*
IndustryArena Forum > CAM Software > Mastercam > creating a rad on an arc
Results 1 to 6 of 6
    Feb 2008
    4
    Hey guys, ive been lurking the site for a while getting lots of great tips along the way. Now i need some more help with a problem ive been racking my brain over.
    I have a 4inch diameter x 4.0 long piece of plastic round bar with a flat 2" deep cutting basically a 1/4 of the part away. there is a taperd slot thru the center 1.325 wide coming out with a .080" rad around the end where the slot comes thru on the diameter. I only have mill level 1, so not much to work with but i know i should be able to get this done.
    My problem is I cannot get the .080 rad milled on the part around the end of the slot. I have tried wireframe > ruled/swept 2d/revolved all with different crazy results. lol i am not sure if its just a chaining issue or what. but can someone please give me a hint on which way to go.
    I would love to post a picture of the part but confidentiality stuff comes into play with this part.
    thanks guys
    Dec 2008
    3136
    Bad luck that you don't have solids
    Try <Create>, <Surface>, <Fillet Surface>
    and go from there
    Oct 2007
    36
    Superman is correct. First everything must be covered with surfaces including the interior of the slot. Then you can create filleted surfaces between intersecting surfaces.
    Mill 1 will not cut surfaces can you use a contour with a Rad mill? does the slot have corner rad. if so how big. what is the angle of the slot? what is the height of the slot? attached is a guess at what this looks like. with the back full diameter having the .08 radius.
    Steve Arteman
    www.cad2cam.net
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
    Oct 2007
    36
    I have added a photo to the gallery named fillet_intersection. Sorry, the graphics are bad. It conveys the idea.
    do you have 4 axis capability on your mill? if so radius mill contour if you had mill level 3 a finish blend toolpath would work well. Check my site under free help videos I have an example of blend
    steve arteman
    www.cad2cam.net
    www.cad2cam.net
  1. Creating tools??? Can it be this bad???
    By honk in forum EdgeCam
    Last Post: 04-27-2012, 07:39 PM
  2. creating a dome in x2?
    By ZipSnipe in forum Mastercam
    Last Post: 03-22-2009, 06:42 AM
  3. Creating Toolpaths for IGS
    By dneisler in forum Mastercam
    Last Post: 01-14-2007, 03:37 PM
  4. need help in creating outline
    By bentecc in forum Autodesk
    Last Post: 10-19-2006, 10:58 PM
  5. Creating a PCB?
    By GunnySnow in forum CNC Machine Related Electronics
    Last Post: 06-15-2004, 04:11 AM
