588,357 active members*
7,523 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > Artgrave 2002 - depth on Z-axis - how to?
Results 1 to 6 of 6
    Oct 2009
    Hello. System description:
    SD3025D on COM1. Set: 19200/8/N/1/RTSxCTS/N
    Win2k3SP2 - ArtGrave2002 licensed
    Com Port Toolkit in Capture mode for a listening on COM1 port
    Problem: I am unable to set depth on Z-axis. e.g. I have character "I" on my working sheet. By 2D ToolPath I am generating adequate path for engraver:
    When I set "lift" parameter to "0" depth on Z-axis is independently on my other settings allways 80 mils = 1 mm: (from COM port sniffer)
    IN;PA;;PU797,6348,0;PD797,6348,0;PD797,6348,80; (etc.)
    if I set "Lift" to e.g. 5 mm, list is changed:
    IN;PA;;PU797,6348,-400;PD797,6348,0;PD797,6348,80; (etc.)
    Where is possible to "vector objects" to set Z-axis depth different from 1 mm (80 mils)? Where is set this "80"?
    Thanks!
    Nov 2009
    Please help me
    Hello. I bought artgrave 2002.But it's Chinese version. Please send me 2D, 3D and other these group buttons command window pictures?
    Please
    Dec 2010
    you need artgrave 2002
    hi all you need artgrave 2002 english ver email me: [email protected]
    Feb 2015
    Re: you need artgrave 2002
    Quote Originally Posted by atex1 View Post
    or the latest one
    Nov 2011
    Quote Originally Posted by ilyas_khan View Post
    or the latest one
    Hi can somebody help me find artgrave in English version?
    Jan 2015
    5
    Re: Artgrave 2002 - depth on Z-axis - how to?
    文泰出国啦?
  1. setting z depth of cut V25 3 axis pro
    By phantom1500 in forum BobCad-Cam
    Last Post: 12-28-2012, 01:29 AM
  2. Replies: 2
    Last Post: 02-04-2012, 05:27 PM
  3. Curve 5-Axis depth of cut
    By coykiesaol in forum Mastercam
    Last Post: 12-21-2010, 10:23 AM
  4. Z-Axis depth guide sensor ?
    By deleteallusers in forum Mechanical Calculations/Engineering Design
    Last Post: 07-17-2007, 06:38 AM
  5. Z axis depth not correct
    By jtriggs in forum Mach Mill
    Last Post: 12-27-2006, 06:52 AM
