603,800 active members*
4,444 visitors online*
Results 1 to 10 of 10
    Feb 2008
    66
    adjust the lense
    it's must fix your problem
    adjust from lense after the tube first then go to next lens.
    the laser must hit the middle of lens.
    you must have VCD, how to allign the lens.
    it's just turn the crew beside the lens.
    Dec 2008
    1258
    Quote Originally Posted by Huahahahahaha View Post
    adjust the lense
    I think you mean to adjust the mirrors so the laser is centered on the lens.
    It is usually best to align with the longest beam path and then check at the shortest path distance.
    Zax.
    May 2010
    dibby,if you bought is a chinese machine,i think they will give you a adjusting crossing.you can insert this on the lens and then input a paper in the crossing,then press the laser to test.first from the nearest place to the distance place,and make sure the burning crossing is at the same center place of paper.Test the lens one by one.
    and beside the lens,it will have three screws which is used to adjust the heigth,left and right sides.
    Hope this can help you.
    [email protected]
  1. Start to Finish help. What laser engraver will do the job?
    By 2A-TB@ThePatch in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-17-2009, 02:09 AM
  2. Laser Auto start
    By grinnabhat in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-26-2009, 03:23 PM
  3. Replies: 4
    Last Post: 01-06-2009, 05:20 PM
  4. one start or two start lead screw
    By Pinhead in forum DIY CNC Router Table Machines
    Last Post: 11-23-2008, 05:32 AM
  5. Single start vs double start ballscrew.
    By darik in forum Linear and Rotary Motion
    Last Post: 03-22-2007, 01:53 AM
