587,625 active members*
3,436 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 11M, 6T Where to get G-Code Transfer Program?
Results 1 to 9 of 9
    Oct 2006
    142
    Smile Fanuc 11M, 6T Where to get G-Code Transfer Program?
    Hello.
    I just brought CNC machines.
    One with Fanuc 11M controller, another with 6T controller.
    Since i don't have any CAM program.
    Can anyone please advise where to get G-CODE transfer program from the PC into the controller?
    Thank you very much in advance.
    Jeff Newbie.
    Oct 2006
    142
    Oh by the way,
    How do you recommend wiring 25 pins (Fanuc controller) to 9 pins (PC)?
    Thank you soooo much.
    Jeff
    Jun 2008
    1511
    Here are a few links to other threads that have the attachments for the pinout and parameter settings.
    http://www.cnczone.com/forums/fanuc/...lp_please.html
    http://www.cnczone.com/forums/fanuc/...10t_rs232.html
    Stevo
    Dec 2003
    24220
    http://www.cadem.com/free_dnc_drip_f..._machining.htm
    I have always used the 3 wire cable version.
    Al.
    Attached Files Attached Files
    Albert E.
    Feb 2010
    Al the Man
    Tried to download the NC lite free program, will not work, any ideas?
    Thanks,
    SteveY
    Dec 2003
    24220
    I just downloaded the new version today, now you have use the link that shows up when the program installs to get the key # off the site.
    If it is a PC not on the internet, you have to transcribe it over by hand.
    Al.
    Albert E.
    Sep 2010
    1230
    Quote Originally Posted by cjchands View Post
    Oh by the way,
    Jeff
    Jeff,
    The info Al The Man pointed you towards is good, but I'll add a little about the handshaking.
    1. The pin out shown in Fanuc_6m.pdf will allow either Xon Xoff (software handshaking), or with the transfer software set for RTS/CTS (hardware handshaking)
    2. The pin out shown in Fanuc 6 RS232.pdf shows a Null Modem and a Full Handshaking pin out. The Full Handshaking configuration will allow for either Software or Hardware handshaking, whilst the Mull Modem cable will only accommodate Xon Xoff; the reason being is that the RTS/CTS lines are bridged, as are the DSR/CD/DTR lines. This means that the hardware handshaking components of the respective Uarts are held high.
    3. If you use software handshaking, and you construct your own cable (sometimes necessary when a fairly long cable is required), then you only need the bridging of pins at the machine end, the following pin out will work; there is no requirement to bridge the pins at the PC end. The bridged pins at the machine end are to keep the machine's Uart happy. Software handshaking only uses transfer lines 2 and 3 and the Signal Ground 5 to 7
    4. If you are going to drip feed (DNC) to the machine, then look for a software package that allows initiation of the transfer from the machine. In other words, the remote device is made ready and will wait for an Xon from the machine, that will be generated when the cycle start button is pressed, before it starts sending. DNC is accomplished by using Tape Mode on the machine, as opposed to Edit Mode when sending a program to the machines memory.
    Regards,
    Bill
    Machine End------------PC End
    25 Pin-------------------9 Pin
    2------------------------2
    3------------------------3
    7------------------------5
    4--
    | bridged
    5--
    6--
    | bridged
    8--
    | bridged
    20-
    Oct 2006
    142
    TYVM all for helpful comments.
    Jeff
    Dec 2003
    24220
    I usually bridge the H.W. H.S. on the PC end just to avoid any problems, also if not, when using programs like CademLite, the port diagnostic will show an error as it checks the H.W. H.S.
    The DNC systems like Cadem will allow the request of a file off an unattended server, the operator sends a very short program that has the file number in it and the server waits a predetermined delay before transmitting the file, this is to allow the operator to switch over to File Input and then wait for the server file.
    Al.
    Albert E.
  1. sample g code program for hitachit 48v fanuc 6mb
    By beekeeper in forum G-Code Programing
    Last Post: 08-12-2010, 04:58 PM
  2. Fanuc 10T Program Transfer Tool
    By navin2507 in forum Fanuc
    Last Post: 07-09-2010, 07:18 PM
  3. program transfer between CNC and PC
    By sinha_nsit in forum Fanuc
    Last Post: 08-01-2009, 11:03 AM
  4. NC Transfer Program
    By JamesBond in forum Uncategorised CAM Discussion
    Last Post: 04-08-2009, 12:40 AM
  5. transfer of program
    By Dar in forum Bridgeport / Hardinge Mills
    Last Post: 09-14-2007, 03:43 AM
