603,978 active members*
1,952 visitors online*
Results 1 to 11 of 11
    Mar 2006
    93
    Unhappy transfer of program
    i need help guys.
    baude rate set at2400.
    made up 232 cable
    wont transfer program
    [extin/output not ready]
    had machine in edit . is there something i,m missing? what do you think Gus? help please
    Dar
    May 2004
    402
    Be quite helpful to know what contoller you are trying to either load or dump from, and what software you are using at the other end of the link. Dependant on controller it may also depend on which machine it's fitted to and thus how it is configured.
    Vague questions will result in vague answers whereas specific questions may get you useful answers
    Andrew Mawson
    East Sussex, UK
    Mar 2006
    93
    program transfer
    maybe this will help?
    bp series 2 r2c3
    heidenhain tnc145
    ez cam
    9 pin connector on pc
    cable made using manual discription
    does this help?
    Dar
    May 2004
    402
    Sorry, no experience with either TNC145 or ez cam. With my TNC151b I initially had loads of problems as I failed to understand that it could exist in several 'modes' when intending to do a transfer. I found that using TNCremo from Heidenhain (free download) and the cable in their manual (also free download) eventually got me going. TNCRemo has a mode compatible with TNC145 so it may be worth your while trying it.
    Andrew Mawson
    East Sussex, UK
    Mar 2006
    93
    me again
    i went to heidenhain site but wasn,t able to find it. i was hopping we were just pushing the wrong buttons to make it transfer.
    Nov 2006
    925
    Dar,you can download the software here.
    http://filebase.heidenhain.de/public/?open[]=64&open[]=55#GROUP55
    and here
    http://www.heidenhain.com/?/ca2243_1...ware-3083.html
    Mark.
    Mar 2006
    93
    Talking pc to tnc???
    thank guys i,ll give that a try
    Mar 2006
    93
    cable wiring
    does anyone have the correct wiring for the rs232 cable when going from a25 pin machine to a 9 pin pc. heidenhain tnc145 on series 2 r2c3. i can,t even read those little numbers without a magnifier.
    thanks Dar
    May 2004
    402
    As per the response to your other thread on RS232 cables, this is the cable I use from my TNC151b to the 9 way on my PC:
    (25way TNC) <9 way PC>
    (2) - <2>
    (3) - <3>
    (4) - <8>
    (5) - <7>
    (6) - <4>
    (7) - <5>
    (20) - <6>
    Andrew Mawson
    East Sussex, UK
    Jan 2007
    333
    transfer of program
    Hth
    Mar 2006
    93
    rs232 cable
    thanks to everyone especially bborg the no handshake one worked. sure is hard to solder wires into those little bitty pins
    Dar
  1. harrison trainer program transfer problem
    By uilleann in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-29-2020, 01:31 PM
  2. NC Transfer Program
    By JamesBond in forum Uncategorised CAM Discussion
    Last Post: 04-08-2009, 12:40 AM
  3. Inexpensive Wireless Intranet Based Program Transfer to Multiple Machines
    By ChopperDoc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-21-2006, 06:36 AM
  4. program transfer problems
    By johnd in forum Mach Mill
    Last Post: 12-24-2005, 10:27 PM
  5. Program transfer software??
    By MattMachinist in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-22-2005, 08:05 PM
