603,330 active members*
3,565 visitors online*
Page 16 of 75 614151617182666
Results 301 to 320 of 1507
Hybrid View
    35494
    No, the g-code window is the standard Mach3 window, and that's how it works.
    You can probably configure your CAM program to add line numbers to your g-code, so they'll be displayed at all times.
    Jul 2011
    42
    Hi Gerry,
    So I have the probing down now. Thanks!
    When I'm doing a tool change Mach is crashing when I hit cycle start to resume. I just get the hour glass. Any idea?
    35494
    Yes, you're probably using the lockdown version 3.43.022, which has nasty M6 macro bug.
    It should work with the latest development version, but I personally prefer the old lockdown, 3.42.040.
    Jul 2011
    42
    Darn! I should have checked the version number. It's the latest lockdown. I had read about this error but I ASS-U-ME-d that it was an older version than the latest lock down.
    Is there any way to revert to 3.42.040 and keep all of my mach config settings? - like, so I don't have to re-input the config manually?
    35494
    You should be able to just run the installer without losing anything.
    Back up your .xml file just in case.
    Apr 2006
    3498
    Hi Gerry, do not forget to watch the following thread by Roman.
    http://www.cnczone.com/forums/open_s...onic_home.html
    If you implement the backlash compensation described by Roman in his thread this will be a revolution in Mach world.
    Regards
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    35494
    I've sent out what I think will be the last update. I had 3 or 4 emails bounce back, so if anyone didn't receive it, let me know.
    The main update is to the probing wizard, which got a few new features.
    Kyel Smith graciously donated two modified widescreen versions (1650 and 1920 wide) which are included in the update.
    Thanks to everyone for their support, and spreading the word about the screenset!!
    Jul 2011
    5
    Re: Mach3 2010 Screen set
    Hi Gerry,
    I Purchased your 2010 screenset back in 2013 but never received any updates.
    If there is any can you please send them to me?
    Also have a problem now. I Had to go overseas for about 2 years now i'm back and started my CNC to see if everything is still working but no movement from the motors.
    Looking at the DROs I get nothing. What could be wrong? The machine was working perfect before.
    Gus
    Dec 2007
    101
    Are you going to add a feed rate DRO? I would be interested in purchasing the screen set if it had that feature.
    35494
    It's on the bottom of the screen, and has been there for about 8 months.
    Dec 2007
    101
    Whoops my bad, never saw it. (chair)
    Oct 2007
    152
    Hi Gerry
    I have purchase your screen set and install it.
    I was wondering if it would be much trouble to ad this feature, when someone moves the mouse pointer over the icons that there would be a pop up identification of that icon.
    Thank you
    Oct 2008
    1660
    I second that. Somewhere on the Mach forum I think Brian showed how hints
    could be utilized.
    Richard
    Quote Originally Posted by BOBINETTE View Post
    Hi Gerry
    Thank you
    35494
    Sorry, but there's no way to do it unless it's a Flash screen.
    Oct 2007
    152
    Thank you for the reply; I was just thinking that it could be useful
    35494
    While zeroing my machine yesterday, I managed to get it to hit the Z limit switch a few times. The issue was a large Material Offset without enough clearance.
    So I modified the auto zero macros so this can no longer happen.
    I also discovered that I included the wrong 2010x.set file in the last update.
    I just sent out the fixes in V1.1.2 a little while ago. Email me if you didn't get it or have any issues.
    Thanks.
    35494
    Thanks.
    Sep 2011
    1183
    Question
    Gerry, I have Mach3 version 3.43.022 ans my screen or monitor is set at 1280X1024 will the Mach3 2010 will this be ok?
    Lou
    35494
    You can't use that version of Mach3, as it has a bug with tool changes. You can either use the latest development version, or get an older version, like 3.42.020 or 3.42.040.
    The 2010 screen only works at 1024x768, so on a larger monitor like yours, it won't fill the entire screen. It'll be a floating window that you can move around where you want it. It works perfectly fine like this, but it won't fill your entire screen.
    Sep 2011
    1183
    Gerry, thanks I will see how to change my version of Mach3 I will be purchasing your screenset.
    Lou
  1. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  2. Econo-Probe Setup with Mach3 + Ger's 2010 Screenset
    By jmc2010 in forum CNC Machine Related Electronics
    Last Post: 06-24-2014, 04:21 AM
  3. G100 + Mach3 2010 screen auto tool zero
    By Menatep in forum G-REX
    Last Post: 05-02-2014, 10:13 PM
  4. Strange Issue with 2010-4 Screen Set in second machine profile
    By JoeKumanchik in forum Mach Software (ArtSoft software)
    Last Post: 03-30-2014, 11:27 PM
  5. New Mach3 Router Screen
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 03:06 PM
