Are you going to add a feed rate DRO? I would be interested in purchasing the screen set if it had that feature.
It's on the bottom of the screen, and has been there for about 8 months.
Gerry
UCCNC 2017 Screenset
Mach3 2010 Screenset
Whoops my bad, never saw it. (chair)
Hi Gerry
I have purchase your screen set and install it.
I was wondering if it would be much trouble to ad this feature, when someone moves the mouse pointer over the icons that there would be a pop up identification of that icon.
Thank you
Sorry, but there's no way to do it unless it's a Flash screen.
Gerry
While zeroing my machine yesterday, I managed to get it to hit the Z limit switch a few times. The issue was a large Material Offset without enough clearance.
So I modified the auto zero macros so this can no longer happen.
I also discovered that I included the wrong 2010x.set file in the last update.
I just sent out the fixes in V1.1.2 a little while ago. Email me if you didn't get it or have any issues.
Thanks.
Gerry
Thanks.
Gerry
Gerry, I have Mach3 version 3.43.022 ans my screen or monitor is set at 1280X1024 will the Mach3 2010 will this be ok?
Lou
You can't use that version of Mach3, as it has a bug with tool changes. You can either use the latest development version, or get an older version, like 3.42.020 or 3.42.040.
The 2010 screen only works at 1024x768, so on a larger monitor like yours, it won't fill the entire screen. It'll be a floating window that you can move around where you want it. It works perfectly fine like this, but it won't fill your entire screen.
Gerry
Gerry, thanks I will see how to change my version of Mach3 I will be purchasing your screenset.
Lou
If you install the latest version, you can just run the installer and install it right over the top of the existing one.
However, I'd recommend one of the older versions I mentioned, which can be found at the Mach3 FTP site, in the Mach folder.
Those should be able to be installed the same way, but you might want to remove the driver first. Go to device manager, and uninstall the Mach3 Driver, found under Mach Pulseing Engine. Then reboot the PC before installing.
Gerry
Gerry I found it I will uninstall the driver and install Mach3Version3.042.020.exe and see if it works..
Lou
Gerry it worked thanks I will put my order in a few..
Lou
Gerry, what version is this up to? I know I recall seeing emails about updates, but I have been doing just about everything but running my machine, so I haven't even followed in a while. Guess I should figure out where I should be and get the software there.
Wood neophyte.
1.1.2
Gerry
Ok, next time I run out to the shed I'll boot up my machine and see if I can find what it is running. Thanks
Wood neophyte.
I don't think it shows a version # anywhere. If you haven't updated it in the last month, you probably have the original version.
Gerry
Click help and about you will see what version you have..
Lou
