587,999 active members*
2,248 visitors online*
Page 17 of 17 7151617
Results 321 to 327 of 327
  1. #321
    Apr 2012
    230
    Quote Originally Posted by Marti View Post
    thanks. I was looking at one of those handheld electric stencil cutters and then thought the laser would be a lot cleaner, plus it could engrave too. I've got an old computer with a writable cd player, so I was thinking of using it if it would work. You've got me thinking about how to tear everything apart for parts. ... any ideas on how to use an old copier? I've salvaged a desktop copier years ago from my nieces husband for the mirror/glass, but wasn't sure what to use it for.
    to build a laser like mine is very simple using salvaged items.
    Your going to have to think of how big the foot print will be and build around that.
    I myself built the first 1 around what belts and pulleys I could find and cost was low
    I'm not sure what you have to work with and without seeing it first hand it would be like leading the blind
    Your best bet is make a list
    1 arduino UNO
    2 stepper motors
    2 drivers for stepper motors
    2 belts
    2 pulleys
    4 rails/bearings
    1 laser diode
    And so on that is just the surface of items needed
    http://youtu.be/9dTS1A2F4j8
  2. #322
    Feb 2013
    195
    Quote Originally Posted by RMHCNC View Post
    1 arduino UNO
    2 stepper motors
    2 belts
    2 pulleys
    4 rails/bearings
    1 laser diode
    I've got the motors, belts, drivers and skate bearings, but I don't have an arduino UNO and I was looking at an (800mW) 808nm TO-5 9mm laser diode on ebay for $15.99, but wanted to see what you used. I don't think it would have to be very big, just large enough to cut stencils (18"-24") and possibly engraving on tile and wood. I've seen where they catch on fire easy, so it's not something I would want to use a lot, plus it's harmful to your eyes so I'm not sure whether to enclose it or just use goggles.
    I've only got a small space to put all my tools and now that my building is jacked up, I can start building some tool carts with wheels. I want to use as many flip top carts as I can to save on floor space. I thought I had a good idea when I put shelves on one end of my building, but now I'm gonna put built in shelves on the cart, i.e., sanding belts on the cart with the sanders, glue, dowels and jigs on the workbench, etc. It's nice having them on the wall, but I think it would be more practical to have everything in one spot.
    Are you still cutting metal, or doing wood?
  3. #323
    Apr 2012
    230
    I can cut aluminum, wood and plastics on my small 16x16 mill
    I am using it to build a much larger and more powerful mill that will be running a 2.2kw spindle and have a travel of 1000 mm x and y axis
    Everything really steamed from my laser cnc. I now use it for stencils and testing with black anodized aluminum but that's bin put on hold for the above mentioned large mill.
    As for the laser you mentioned I believe that is in the infrared level of lite and you really should not play with it as you can't see the beam.
    That is the main reason I used the 445nm. Even a laser diode out of an old blue ray burner can be used and powered @.125w. It will be enough to burn wood and stencils no problem. You can get an arduino nano from eBay for like $10 then all you need are 2 driver boards and the laser. Let me know what you plan on doing and I will see what I can help you with when it comes to the wiring and controls
    Here is a pic of the rails and z axis parts I have collected so far
  4. #324
    Apr 2012
    230
    So I'm on the fence here with the decision of ballscrew or R/P?
    When I look at the cost, it seems about the same I just have not worked with R/P in any way
  5. #325
    Apr 2012
    230
    Attachment 210818
    Attachment 210820
    Here are two pics of the arduino I used, you can find them for around $7 on eBay
    And here is the driver stepstick 4988 $5 each
    Attachment 210826
    I then made my own heat sinks for the drivers as they tend to warm up
    Attachment 210830
    Attachment 210832
  6. #326
    Feb 2013
    195
    I got some gears and tracks and they were a lot smaller than I thought. I guess with a laser they might work, but I don't think they will work with the weight of a router. So I'm curious to see what you come up with
  7. #327
    Feb 2013
    195
    Attachment 210818
    Attachment 210820
    Attachment 210826
    Attachment 210830
    Attachment 210832
    I have some of those easy boards you told me to get. I've got to go through all my stuff and start separating all my different projects and see what's left that I need to get for each. It will be nice to get things started and finished.
  1. Home Made internal spindle stop!
    By widgitmaster in forum Mini Lathe
    Last Post: 08-13-2016, 10:46 PM
  2. Home made electronic for Spindle control
    By dinko in forum CNC Machine Related Electronics
    Last Post: 05-31-2012, 02:52 PM
  3. 100000 rpm spindle home made
    By goldi80 in forum Hobby Discussion
    Last Post: 10-14-2011, 03:43 AM
  4. My home made cnc - Need a good spindle?
    By Rajpage in forum DIY CNC Router Table Machines
    Last Post: 11-02-2010, 09:03 AM
  5. Hard drive servo spindle are any good for home made lathe?
    By patriciooholegu in forum Servo Motors / Drives
    Last Post: 12-08-2007, 04:48 PM
