588,676 active members*
6,139 visitors online*
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Nov 2015
    13
    Re: Ball screw size/pitch?
    I have this 10mm diameter ballscrew with around 3mm pitch, can it be used to replace the leadscrew of the X2 minimill so for CNC conversion?
  2. #22
    Aug 2004
    782
    A1.
    Whats the original D on the screw ?
    Never go to a smaller screw, and if possible, always go for a thicker one.
    Rigidity is everything, and rigidity goes up as screws get thicker.
    A2: Yes.
  3. #23
    Nov 2015
    13
    The original screw is 15mm.
  4. #24
    Jan 2007
    1795
    use 10 mm lead on the 48 long, 20 mm lead would ve ideal on 96 length... but 10 mm still good...
    don't worry on accuracy mumbo jumbo.. doesn't matter on 8 feet length 1/100...
    you cant measure on that length the difference.. you don't even can make part with that accuracy in a home shop..
    additionally if you make one part, then your another part will match for the first..
    instead tedeious calculations, use at least nema 34 motors... 900 oz on 48 and at least 1200 on the 96 length..
    on Z pending of spindle, but at least 500 oz with 5 mm lead of screw.. these are working pairs..
  5. #25
    Nov 2015
    13
    Hi, can't quite understand your reply.
Page 2 of 2 12
  1. Ball nut arbor size for 1605 ball screw
    By kdoney in forum MetalWork Discussion
    Last Post: 04-08-2020, 07:45 AM
  2. EZPATH S ball screw size
    By mmckell in forum Bridgeport / Romi Lathes
    Last Post: 10-27-2011, 05:36 PM
  3. What size ball screw ???
    By milldrillmaniac in forum Linear and Rotary Motion
    Last Post: 02-03-2009, 10:16 PM
  4. Ball screw and Stepper Motor Size
    By ericdwilso in forum Linear and Rotary Motion
    Last Post: 05-21-2007, 08:40 PM
  5. What speed and pitch ball screw
    By Georgie in forum Benchtop Machines
    Last Post: 01-08-2006, 07:14 PM
