588,263 active members*
5,114 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Changing or disabling home position for tool change.
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Feb 2006
    59
    OoooHH! Thats why it is interlocked on the PMC, you have a parts catcher that might get in the way of the tool change. As Jvangelder says you can do the PMC programming on the machine but you have to be careful not to screw up your original program.
    Look at the PMC program and you should see some use for the Gn130.x bits. This are the axis interlock bits, and you should see that the turret control axis is interlocked. Thats the bit you will want to bypass.
    You can bypass it by adding a parallel line that has a K0xx.x and that will unlock that interlock.
  2. #22
    Sep 2009
    84
    Quote Originally Posted by gilchapa View Post
    As well as the sub spindle, the chuck, or depending on the tools, the covers of the machine. You might not want to be at X home to do a toolchange. some of our posts clear the covers by less than a 1/4"
    Thats really not a good idea, one slip on the keypad while setting up and.. you have just indexed your turret into god knows what
    -Jacob
  3. #23
    Feb 2006
    59
    -Jacob[/QUOTE]
    Well I admit I tend to oversimplify things and he will have to make sure that he is programming something safe, but thats the general idea and if MikieD gets it to work he will have an improvement, which is why we are all here dont you think?
  4. #24
    Jul 2012
    SET the PC PARAMETER (D DATA)
    D9.5 Auto Mode x axis interlock
    D7.5 Jog modus x axis interlock
    D12.4 B axis interlock
    after that it should be pssibe to rotate in jog and auto mode in any positin and also without B axis at ref position. if you don´t know how i can explain you to get into this PC Parameter screen.( normally *system->pmc->pmcdgn-> status and there you search for D)
    you can also check these D parameters in your ladder file and there you will find that these data is protecting the turret of rotating....
    usually it is because it is easily to crash your machine thats why you have to set these Parameters a your own risk
  5. #25
    May 2012
    Quote Originally Posted by khaot183 View Post
    I made these changes today and have removed just over 3 seconds of wasted motion from a part that was running 27 seconds! I can't wait to come back to some of our other parts and optimize them as well!
    I wanted to thank everyone that helped me here!
Page 2 of 2 12
  1. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  2. Change position of A axis home
    By mishikwest in forum Haas Mills
    Last Post: 07-23-2010, 08:52 AM
  3. Changing home position
    By positiverake in forum Fanuc
    Last Post: 12-29-2009, 09:06 PM
  4. Changing/resetting the table position during a tool change?
    By Jim Ster in forum Mori Seiki Mills
    Last Post: 08-13-2008, 01:31 PM
  5. Change TL-1 Home Position
    By jmanjohns in forum Haas Lathes
    Last Post: 06-18-2008, 10:56 PM
