603,360 active members*
4,372 visitors online*
Page 21 of 21 11192021
Results 401 to 405 of 405
  1. #401
    Feb 2010
    3450
    Mine still needs to be converted. Prolight slant bed minus oem controller.
  2. #402
    Dec 2016
    Re: Slant bed CNC lathe from scratch
    this pic not open
  3. #403
    Dec 2016
    pliz send all pic to my email not open for me
    [email protected]
  4. #404
    For those with future intentions when doing a mineral casting fill you won’t have any leakage if done correctly. I’ve never had any leak out using “casting” epoxy, correct aggregate mixture to silica, aluminum oxide, and preferably adding zeeosphere in the mix and it will be a peanut butter consistency. Roll in a ball, toss it in the air if it stays together when landing in hand after a 3ft toss the mixture is correct. If it splats, leaks, or falls apart it is incorrect. Do not ever use marine epoxy, bar table epoxy, or any general 2:1, 1:1 epoxy mix not intended for casting if you want positive results. Casting epoxy cost around $100/gallon.
  5. #405
    Sep 2020
    The best gaming mouse is an important apparatus for arriving at your maximum capacity. You need a mouse that will not keep you down. One that puts everything readily available. best 12 button gaming mouse
    https://gamingmousetech.com/what-is-...-gaming-mouse/
  1. CNC lathe scratch build!
    By aarongough in forum Vertical Mill, Lathe Project Log
    Last Post: 02-07-2013, 10:06 PM
  2. Looking for Specs for a scratch built lathe
    By breathe in forum Vertical Mill, Lathe Project Log
    Last Post: 06-16-2011, 12:56 PM
  3. From scratch. Lathe, Mill, or maybe both.
    By MrBean in forum Vertical Mill, Lathe Project Log
    Last Post: 10-28-2010, 01:25 PM
  4. CNC Lathe from Scratch
    By mackeym in forum Vertical Mill, Lathe Project Log
    Last Post: 06-02-2010, 12:20 AM
