588,225 active members*
4,826 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > v26 plunge point lead in location...how to change?
Page 3 of 3 123
Results 41 to 48 of 48
  1. #41
    Oct 2007
    446
    Re: v26 plunge point lead in location...how to change?
    thx engine guy..yup thats it....
  2. #42
    Jun 2008
    1838
    Quote Originally Posted by airbrush View Post
    My head hurts!...
    so the plunge point also determine where the start of cut begins?
    thx for all the help...
    Your head hurts? How do you think ours feel, just been online and bought shares in the firm that make Asprin
    Yes, you`ve got it, the start of the feed cut at DOC (assuming that you actually set one, otherwise the software will use it` own default)
    Here is some more "pain" for you just in case you haven`t noticed why I used the values I did.
    You wanted a DOC of 0.25" but didn`t want a zig zag ramp, just a little math will do it for you, if a longer shallower ramp is desired then remember that a straight plunge is at 90 Degrees to the plane so a 1.0" distance ramp from plunge point going to a 0.25 DOC, then as 0.25 is a quarter of 90 therefore a quarter of 90 degrees is a ramp angle of 22.5 degrees which will give a single ramp in without any zig zag as in the example
    Hope that`s enough for you for today, keep taking the pills
    Regards
    Rob
  3. #43
    Oct 2007
    446
    right ...makes sense..thx
  4. #44
    Oct 2007
    446
    actually it doesn't zigzag at all....you can just set your angle to whatever you want set your ramp length...that can even be something greater (say 2 inch etc) doesnt matter..it will just go 45 degree to the top of part...
    the zigzag issue i was getting was because i was setting the angle to - , instead of the ramp length to -
    so problem solved...and no math involved...(which doesn't hurt my head)
  5. #45
    Jun 2008
    1838
    Great, glad you are up to speed with it now
    The software is pretty good (Even the old V26) but it isn`t perfect, there has to be a fair bit of input from the user, known as "the learning curve"
    Regards
    Rob
  6. #46
    May 2013
    701
    Quote Originally Posted by The Engine Guy View Post
    Regards
    Rob
    Rob
    are you able to get it to start on the narrow width on the same example having trouble starting in that area.
    What you have shown is really good to know
    RAF.
  7. #47
    Jun 2008
    1838
    Quote Originally Posted by RAF. View Post
    Rob
    RAF.
    RAF
    Well, yes and no, the "Lace Angle" in that type of pocket is set and can`t be changed so what happens is the toolpath starts and runs at an angle which can mean it starts to ramp outside the pocket, this is not good, when I was playing around with the file "airbrush" provided that`s what I found so temporarily dumped that idea
    However there is a small work around that I did but didn`t upload as it wasn`t what the OP wanted, anyway, what I had to do was set the plunge point level with or higher than the lower end of the side line of the pocket boundary and it does go in the correct direction, just means the tool ramps in and runs horizontally across the pocket to the end point of the side line and then runs normally from there (If any of it can be called normal)
    I didn`t go into it any deeper but here is the file where I tried it, have a play and see what you can come up with, it is an odd little cunundrum
    I always "Pocket Out" as that doesn`t have the cutter doing a long cut at the DOC cutting a slot, starting from the center and working out means the cutter has a very short cut at full envelope at full DOC, but as they say "each to their own"
    Enjoy
    Regards
    Rob
  8. #48
    Aug 2007
    24
    RAF
    If you need to control the start point for a pocket you need to create a contour from your geometry, where you start the contour will control the start point of the pocket.
    Obviously you must reselect the contour for your pocket.
Page 3 of 3 123
  1. Selecting Start Point for Plunge Roughing - V28
    By geoffw in forum BobCad-Cam
    Last Post: 01-11-2016, 03:59 AM
  2. Help changing plunge and retract location
    By SWATH in forum Visual Mill
    Last Post: 01-06-2011, 10:22 PM
  3. Replies: 3
    Last Post: 10-30-2010, 04:31 AM
  4. need drill cycle to post every point location.
    By kesparate in forum Post Processors for MC
    Last Post: 03-11-2009, 04:40 PM
  5. Chaining from specific start point for plunge
    By jrrhotrod in forum Mastercam
    Last Post: 04-19-2008, 07:46 PM
