588,694 active members*
6,690 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Optimum BF20L CNC conversion using the Smooth Stepper
Page 5 of 31 3456715
Results 81 to 100 of 602
  1. #81
    Mar 2009
    1114
    I don't have a specific wiring diagram but here's generally how all VFD's work with a 0-10v external speed reference.
    You would hook up your C32 0-10v output to the analog input on the VFD (Circled in red). Then you just need to set the parameter within the drive to take it's speed reference from a 0-10v analog signal. That's all that's to it really. Pretty much everything else is done within Mach3 to setup the spindle.
    Note that diagram was taken from the GS3 drive manual, sold by automationdirect.com
  2. #82
    Jun 2011
    Cheers again :cheers:and you are bang on I can use my existing C32 BOBCNC4PC
    I'm looking at around a 1.5 to 2HP three phase AC motor and the DURApulse Sencorless AC Drive to suit The best way to buy industrial controls--low prices, fast shipping and superior service..
    I came across another link here too for anyone else like myself learning about Sensorless vector control variable frequency drive (VFD) How does Sensorless vector control VFD work?: AC Drive
    as you said it's not a cheap move either but from what I've been reading and what I've been told from some suppliers here at home the actual electricity/utility cost in running a three phase motor could actually pay for the product over time (depending on hours running of course) as compared to a single phase DC motor the power consumption of a three phase AC motor is minimal.....and I didn't know that either...
    Eoin
  3. #83
    Mar 2009
    1114
    Sounds about right. I went with a 2hp motor. One nice thing about AC motors, is they come in standard frame sizes. For instance, any 56 frame motor will fit any 56 mount, weather it be face, or base mount. This makes it easy to swap out motors when necessary.
  4. #84
    Jun 2011
    yeah the 56 chasis was what I was looking at the dimensions look relatively ok 6" diameter and 12" long or in our case high.....and the three phase motor allows up to 3800RPM as opposed to 1800 with the single phase motor. and with a 1:2 ration that allows a max of 7600RPM if the job dictated that requirement, and the three phase motor is even lighter too less weight on the Z axis.
    :cheers:
    Eoin
  5. #85
    Mar 2009
    1114
    Quote Originally Posted by Mad Welder View Post
    :cheers:
    The number of phases doesn't reflect RPM. The number of poles inside the motor do though. 4pole=1800 2pole=3600. But the 4pole has twice as much torque as the 2pole. You never get something for nothing.
  6. #86
    Oct 2008
    2109
    and for those of you who never worked on brass beware the dam stuff sprays tiny sharp needles EVERYWHERE ha my fingers were like small cactus
    Brass, and cheap chinese "iron" castings.
    Bob La Londe
    http://www.YumaBassMan.com
  7. #87
    Jun 2011
    Quote Originally Posted by Starleper1 View Post
    Cheers again:cheers: I wasn’t aware of that and if my understanding is correct here…. hypothetically I could make a belt drive pulley to fit the motor and suggesting here the pulley diameter of 1.5” and then make a spindle receiving pulley with a diameter of 3” I would double the motor RPM at the spindle without decreasing/affecting torque yeah, but if I bought a two pole I would have half the torque regardless of the RPM??
    Eoin
  8. #88
    Oct 2008
    2109
    No. Torque at the spindle would be decreased. That's ok though. Faster speeds are for lighter cuts. Hence why you spin a small drill bit a lot faster than a giant one. As the other poster said, its always a trade off. The only way to get more torque and more RPM at the spindle is to go with a bigger motor.
    Bob La Londe
  9. #89
    Jun 2011
    Quote Originally Posted by Bob La Londe View Post
    No. Torque at the spindle would be decreased. That's ok though..........
    as I'm a newbie don't go all technical but in simplest terms why?
    the brass was from my own stock as that's all I had available to machine ballnut mounts at the time
    Eoin
  10. #90
    Oct 2008
    2109
    It takes more energy to run faster right? You can either go fast or carry a heavy load, but not both unless you also get stronger.
    The average person can sprint pretty fast right. Can they sprint as fast carrying a 100 pound pack? A 200 pound pack?
    Is that un technical enough?
    Bob La Londe
  11. #91
    Mar 2009
    1114
    The easiest way to explain it, is mathematically. The formula for torque is HP x 5252/RPM
    So for instance lets say you use a 2hp motor and through your pulleys you get a max speed of 5000RPM. Horsepower stays the same regardless of speed. If we run it through the formula as follows. Torque = 2 * 5252/5000 you end up with 2.1 lb/ft
    Now take the same parameters but reduce your max speed to 2500RPM. Torque = 2 * 5252/2500 you end up with 4.2 lb/ft. So as you can see the outcome is linear.
    Hope this helps.
  12. #92
    Oct 2008
    2109
    There is a freak though. Stepper motors are always powered at full power. They move by fighting themselves. (actually many controllers reduce power when not receiving step direction signals and the motor is stationary) The net result is that they have better torque figures at the motor shaft with lower RPM so often it works out that using a pulley to increase speed rather than running the stepper at higher speed gives more torque at the screw, spindle, etc driven by the stepper.
    I had to throw that in there just to muddy things up of course. LOL.
    Bob La Londe
  13. #93
    Mar 2009
    1114
    The formula I explained is generally used for induction motors. Steppers are irrelevant here. But your right steppers are a different beast.
  14. #94
    Jun 2007
    3891
    steppers are always under full torque yes, but not power.
    1NM torque at 0 rpm is still 0 output power.
    the same is true for the induction motors. steppers are commanded differently, but they cant be changing the laws of physics
  15. #95
    Oct 2008
    2109
    Smile
    :bat::bat::bat:
    Quote Originally Posted by ihavenofish View Post
    Bob La Londe
  16. #96
    Oct 2011
    The average person run sprint pretty fast right. Can they sprint as fast carrying a 100 pound pack? A 200 pound pack?
    kid gloves on newbie Mad Welder there Bob Director
    "Hope this helps" is much nicer
    Good input though!
  17. #97
    Jun 2011
    Wow interesting turn of events…..
    Yup I can understand that cheers
    The easiest way to explain it, is mathematically…………Hope this helps.
    Cheers again Starleper1 am I correct here in understanding that as you reduce RPM you increase Torque respectively?
    Bob La Londe not sure why the ‘Bats’ image was displayed here with ihavenofish’s post but if there’s something problematic going on here outside of my thread….1>don’t bring it in here as I'm not interested and don’t wan’t to know either and 2> if I’ve misunderstood the ‘bats’ image intentions then cheers for the input lads
    Quote Originally Posted by jdurkin View Post
    Good input though!
    Aw shucks some one is looking out for me
    Eoin
  18. #98
    Oct 2008
    2109
    Look at the smiley before it grows wings. Then say "Doh!" I didn't realize it kept going when I first put it in. Just saw it went from plane to red faced. Actually, my point was valid even if technically its providing no motive power when stationary.
    You asked for a non-technical answer and that was the least technical answer I could think of.
    Sorry, for trying to help. I'll try to remember not to do that again.
    Bob La Londe
  19. #99
    Dec 2007
    2134
    Bob,
    The trying to help wasn't the issue, the issue brought up, (and I apologise if I am reading it wrong), was the condescending and insulting way you responded. The guy's clearly asking for the benefit of more experienced people, not to be insulted and belittled in a public forum. I see a lot on this forum very often unfortunately that some of the more experienced people seem to forget that everyone has to start somewhere, and that start is usually by asking questions, and no matter how silly they might seem to experienced people, to the newbie they are the starting point of their reference view.
    Less attitude and more genuine help would go along way in these forums with a lot of people here.
    cheers,
    Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
  20. #100
    Oct 2008
    2109
    Quote Originally Posted by aarggh View Post
    Bob,
    cheers,
    Ian
    Actually I was not responding to you, hence why I didn't quote you. I specifically quoted the person I was responding to. That's one of the things quotes are for. Had nothing to do with your attitude or your perceptions. I accepted your original problem for what it was and moved on.
    So you don't like my attitude or atleast the way you perceived my attitude. That's really your problem. Not mine.
    I gave the OP exactly what they asked for. A simple not technical explanation by way of analogy. Like I said. I won't make that mistake again. (I tutored a number of subjects in college and exactly that approach was quite successful. I had a number of professors ask if I minded if they used some of my analogies in ther classes.) I also did something I have learned in a couple decades of business. I asked the subject if they understood. All the clever (or not so clever) analogies are useless if you don't verify that it worked.
    I may offer somebody else my "attitude" and opinion or explanation, but this poster will not benefit (or be harmed) by my opinion again, not because you had a problem with your personal perception, but because of their own projection of a nonexistant outside problematic relationship of some kind.
    I personally think some of the "more experienced" people here don't hear what people actually ask sometimes. Their experience cloggs up their ears.
    Cheers? Really?
    While not quite at the same level I always found that analogous to the little kid who thinks its ok to expel vitriole at the expense of others if they say, "Just kidding!" at the end of it.
    I am now going to quit following this thread. Obviously I am not welcome here. I wish it didn't still come up in "my replies" though. Can't have everything I guess. LOL. Best of luck to the OP. (sincerely)
    Bob La Londe
  1. Optimum 180x300 CNC Gang tool conversion
    By belli in forum Mini Lathe
    Last Post: 11-25-2015, 10:51 PM
  2. Optimum BF20 G0704 Conversion
    By Winnfield in forum Benchtop Machines
    Last Post: 08-07-2011, 12:16 AM
  3. Smooth stepper
    By dnelso in forum Charter Oak Automation Support Forum
    Last Post: 08-04-2009, 05:07 PM
  4. Optimum BF20L CNC conversion
    By JanHenning in forum Vertical Mill, Lathe Project Log
    Last Post: 03-11-2009, 05:09 PM
  5. OPTIMUM BF20L mill, z-travel exactly from table height ?
    By vroemm in forum Uncategorised MetalWorking Machines
    Last Post: 01-19-2009, 10:01 PM
