588,668 active members*
6,293 visitors online*
Thread: Hoss's G0704
Page 9 of 48 789101119
Results 161 to 180 of 945
  1. #161
    It was brought up last week in other threads about drawbars and TTS with the G0704.
    On the way home from work Friday, this idea came to me.
    It seemed a simple and cheap solution for manual mills in my noggin
    so I bodged it together and it works.
    [ame="http://www.youtube.com/watch?v=FyaZGvcrCB0"]YouTube- G0704 Manual Auto Drawbar[/ame]
    If I was going to keep the mill manual, I'd make a better crossbar that pivots,
    would allow for drawbar removal, a tad more quill travel and keep the drawbar from rubbing.
    It's for "Light Duty", well as "light" as my X2 can handle anyway. Read # 16
    If you want to use stiffer bellevilles, you better bolt the machine down.
    I could manage to compress the ones I used (left over from the X2)
    with just forearm strength, about 750 lbs at the drawbar.
    Works as quick and easy as the Mach 1 system but not as much $$$.
    Should work just as well on X3's, RF45's or any other mill with a quill.
    I was worried the quill handle might break but it seems more stout than I thought.
    If I went with higher spring pressure, I'd replace the handle I'd use with a solid steel one.
    I wouldn't be worried about trying to get too much more though, I know what Can be done on my Freak with these springs.
    Hoss
    Attached Thumbnails Attached Thumbnails IMG_4677_800x600.jpg   IMG_4687_800x600.jpg   IMG_4688_800x600.jpg   IMG_4691_800x600.jpg
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  2. #162
    Feb 2007
    4553
    "Hoss Quick-Draw"
    Hoss,
    Your new "Hoss Quick-Draw" quick change reminds me of the Mach-1 that I have on my Bridgeport.
    Awesome job!
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  3. #163
    Mar 2009
    97
    Hoss - that is OUTSTANDING ... i would not have thought about using the quill that way!!! THANKS .... question ... when you drilled and tapped your head - did you do that with a hand drill or did you remove your head and use a drill press or another mill .... mods for me - with only one such tool are a little more difficult ... i really need a drill press !!!!! and a bandsaw !!!
    thanks again for sharing !!
  4. #164
    May 2005
    2502
    What a wonderful drawbar solution, Hoss!
    Good use of the ole noggin.
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
  5. #165
    Quote Originally Posted by dsdmax View Post
    Reading your question about using a lever to operate the drawbar is what got me thinking.
    I used a hand drill. Careful drilling the upper holes, there's only about 5/8 inch
    of meat before you'll hit the upper bearing in the head. It's hardened, so you
    aren't going to drill thru it, but it could dull the tip of your drill. the lower hole goes thru the head wall
    so you only get about 3/16 threads but it's insurance.
    There isn't room on the left side with the electronic box in the way, the edge is in line
    with the center of the spindle and bearing,
    but you could make the support wider and put the 2 holes side by side into
    the thicker section of the head about 1/2 down from the top.
    Lots of different ways it can be done. just keep in mind what you could be drilling into.
    I have a links to sources for the bellevilles I used here.
    http://www.hossmachine.info/projects...ower%20drawbar
    There are pics of the head exposed here.
    http://www.hossmachine.info/G0704.html
    Hoss
  6. #166
    Quote Originally Posted by BobWarfield View Post
    Cheers,
    BW
    Do my best thinkin when I'm trying not to.
    Hoss
  7. #167
    Mar 2008
    3655
    Most ingenious Hoss. Kudos!
    CR.
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
  8. #168
    Here's the new pivoting version, folds down flat to the front, all aluminum.
    Video and print later, time for bed.
    Just sold the idea to a major company who wants to mass produce them.
    Hoss
  9. #169
    Jun 2007
    3891
    Quote Originally Posted by hoss2006 View Post
    Hoss
    but.. but ... it was myyyy idea!!
    *steals hoss's pichurs and scribbles his own name on em*
    :P
    good going there. is it something that will end up as a kit for these and other machines, or are they gonna build it into an off the shelf machine?
    my only concern with your design - as with many designs i see - is it puts pressure on the bearings. no worse that whacking with a hammer of course.
    has to be by far the simplest solution ive seen though.
  10. #170
    Dec 2009
    1416
    Nice!
  11. #171
    Nov 2008
    103
    congrats
    Great job, and congrats on the sale Hoss! What you came up with is much more elegant than the similar designs the Germans have designed in the past (one of which requires a complete spindle swap and $500!).
    My only question/concern isn't so much for the bearings but the quill rack, what's your take on the forces involved/imposed on the rack?
    Can't wait to see your final design for a tool changer for the CNC'd version, a non "Tormach" design with an actual retention knob would be kinda cool.
  12. #172
    Sorry, I wish.
    You know what day it is.
    Hoss
  13. #173
    Jan 2007
    24
    Doh!!!
  14. #174
    Nov 2009
    724
    Hoss, what is the thickness and deflection of your bellevile's
    am about ready to place an order for some from McMCarr
    working on a similar set up on my Sx3
  15. #175
    These are the ones I have from MscDirect that I used here and on the X2.
    http://www1.mscdirect.com/CGI/NNSRIT...44918&PMT4NO=0
    These are the almost exact same ones from McMaster.
    http://www.mcmaster.com/#96445k267/=6h1bxj
    Hoss
  16. #176
    Nov 2008
    103
    Arrrgh, got me!
    Shoot it is April 1st! And I thought finally someone actually made a decent profit!
  17. #177
    Jokes on me I guess.(wedge)
    Hoss
  18. #178
    Nov 2009
    724
    Hoss
    thanks Hoss
  19. #179
    Jun 2007
    3891
    Hoss
    too early in the morning. haha.
  20. #180
    Well if any of these suppliers start offering it, you'll know where they got it.
    Robert Kearns knows.
    Hoss
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-16-2024, 11:51 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
