588,695 active members*
6,074 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Table / stand to put desktop CNC router on
    Sep 2004
    13
    What do you have your benchtop cnc routers sitting on?
    I have ordered a desktop cnc router, about 28 x 28 overall dimensions and 70 pounds. It is made mainly of alluminum. I was planning on just putting it on a flat, sturdy workbench. The machinist, were I work during the day, said it should be on a 300lb "tool" granite top for flatness and stability. That seems a bit extreme to me. Supposedly, the machinist had problems with a similar router being inaccurate on a standard commercial workbench.
    What do you guys think?
    Have your workbenches/tables caused any problems with cnc routers?
    Tim
    Nov 2003
    634
    Mine is about the same size and is sitting on 1-1/2" particle board counter top supported by 2" metal legs.
    I can't see any problem.
    Jul 2004
    104
    Home Depot has a great workbench they don't advertise, I found them sitting on the 3rd shelf next to the lights. Steel construction, about a 2 inch thick laminated hardwood top, 54 inches long, 2 large ball bearing slide drawers, two shelves, plus freaking large casters for $99. I bought 3 of them!
  1. Replies: 2
    Last Post: 03-10-2006, 02:52 PM
  2. CNC Router Taper Machine
    By hadjcues in forum DIY CNC Router Table Machines
    Last Post: 03-24-2005, 12:02 AM
  3. Need some advice on DIY 24"x24" CNC Router Table...
    By kanankeban in forum DIY CNC Router Table Machines
    Last Post: 06-01-2004, 12:38 PM
  4. buscht's cnc router
    By buscht in forum DIY CNC Router Table Machines
    Last Post: 04-13-2004, 05:43 PM
  5. Cnc Router table Plans and ideas
    By ljoe1969 in forum DIY CNC Router Table Machines
    Last Post: 11-13-2003, 03:12 PM
