588,193 active members*
6,547 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > cant get correct 3d toolpath for simple part in bobcad v23
Results 1 to 15 of 15
    Sep 2011
    I am new to bobcad v23. I am trying to cut my first 3d part out. Seems like it would be very simple to do but I am trying all options I can think of in Cam tree and sim of the cuts using z-level roughing, z - level finish even slice planar are not even close. Cut is missing both 45 degree angels and looks a mess. Is there something I am missing as it relates to operations? The drawing is attached...
    Attached Files Attached Files
    Feb 2012
    I will take a look
    I am learning Bobcad and will try a little problem solving on this--let you know.
    Jun 2010
    104
    Smokey911,
    I'm not sure of your machine's capability but you'll need to cut this part in 3 operations unless you have a good fixturing strategy and a 4th axis.
    Can you send the .bbcd file instead of the .dwg, there are no tool paths included in your attached file.
    Sep 2011
    It is telling me invalid file when I try to upload the file .bbcd... Am I missing something?
    Quote Originally Posted by hkenuam View Post
    Smokey911,
    Jun 2010
    104
    You will need to zip up the file first.
    Sep 2011
    Okay the file is attached. As far as the 3 move cut to make the part, I agree. cut 1 on side, cut to on opposite side and cut 3 to cut the slot... That is the last tool path I came up with. I could never get it to cut out the angle or even come close, thanks for looking...
    Smokey911,
    May 2008
    244
    the first thing you need to check is your post
    not sure you have the correct one selected
    what control are you using,
    if there is not one in your post file go to bc site there should be one
    Sep 2011
    If you mean a post to print the code out below, I have one, it should be selected, if not I definitely have one, for some reason it is just not showing it, sorry. Not sure why it did not come through... It is mach 3...
    Jun 2010
    104
    Smokey911,
    I'm assuming that you are starting with square stock, with three ops on the part. Attached is a modified version of what you had. I didn't do all the tool paths but I think you can see what I did. You may want to make three separate files to avoid confusion (1 per op).
    Hope this helps,
    May 2008
    244
    the reason i ask about the post processor was it had an odd
    name in the box, but if you know it is for mach 3 then ok,
    try smaller step downs in each of your features this will help
    in cutting more of the part, and mabe a ballnose cutter in finish
    to cut this part correctly, you will need mutiple setups as others have said
    Sep 2011
    Thanks for helping hkenuam!
    Looks good in the preview window but I can't open it, I get the version error message. The message pic is attached... Can you save it in version 23? That is the version I have. I guess my version is kind of dated.... Thanks........
    Smokey911,
    Hope this helps,
    Sep 2011
    Thanks for the comments dwood!
    Quote Originally Posted by dwood View Post
    Sep 2011
    Thanks Captain Crunch!
    Quote Originally Posted by Captain Crunch View Post
    Dec 2008
    4548
    Quote Originally Posted by Smokey911 View Post
    Here's a V23 version.
    Sep 2011
    Great! Thanks hkenuam and BurrMan... That is the better way to cut, thanks...
    Quote Originally Posted by BurrMan View Post
  1. Bobcad V24 unable to generate 3D toolpath
    By koosjr in forum BobCad-Cam
    Last Post: 06-20-2011, 05:05 PM
  2. creating toolpath for a simple impella
    By mortzs in forum Mastercam
    Last Post: 05-07-2010, 11:35 PM
  3. BobCad-Cam V21.5 simple program
    By jessey in forum BobCad-Cam
    Last Post: 05-29-2009, 05:42 PM
  4. Problems with 3d part toolpath
    By EvanB in forum BobCad-Cam
    Last Post: 10-22-2007, 09:16 PM
  5. Toolpath correct?
    By cncrunner in forum GibbsCAM
    Last Post: 04-02-2004, 06:50 AM
