588,193 active members*
6,560 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Very complex DXF, cheap/simple Waterjet toolpath creator?
    Nov 2011
    41
    I have very complicated DXF images that get as big as 4' x 6'. They include over 3000 cuts. I've spent 2 days trying to find a CAM software that will work great with the waterjet. LazyCAM can't open the files. I think the closest I have come is SheetCam, but that even seems a bit odd.
    What is the go-to CAM software for me to convert my DXF into NC for a waterjet to cut? Budget is sub-$500
    Jun 2009
    226
    I don't have a specific recommendation as to software but this is what I do when I have a very complicated piece to cut, especially if the pc / software has trouble processing the large file.
    I break the drawing up into several layers and then process each layer as a separate cut sequence. The one thing you must do is that after you have the initial torch ( I use plasma) zero reference point, you can't move anything until the last layer is cut.
    Hope this helps.
    Willy
    Jun 2007
    3735
    Jun 2008
    562
    You could download a trial version of Vectrics Vcarve Pro and see if that can handle it. $600 if you buy.
    Mike
  1. Replies: 14
    Last Post: 02-28-2012, 03:59 AM
  2. Looking for a simple, cheap cnc conversion
    By Millenniumman in forum Benchtop Machines
    Last Post: 10-25-2010, 11:36 PM
  3. creating toolpath for a simple impella
    By mortzs in forum Mastercam
    Last Post: 05-07-2010, 11:35 PM
  4. Simple Plate Design--Waterjet, Mill, Plasma, etc.
    By LateNight72 in forum Employment Opportunity
    Last Post: 10-16-2007, 11:36 PM
  5. Simple cheap CNC router
    By mwalach in forum DIY CNC Router Table Machines
    Last Post: 10-29-2005, 01:08 AM
