588,385 active members*
5,391 visitors online*
    May 2006
    309
    CNC turned sphere?
    Will it be a good solution to use a cnc lathe in order to make wooden spheres? I´ve seen some fantastic result with ordinary lathes on Youtube, but I need to know if this also is possible with a cnc-machine?
    Mar 2015
    426
    Re: CNC turned sphere?
    I make "spheres" on my cnc lathe in aluminum. I use a 3 mm cutoff tool to turn both sides without a tool change. I turn the right side (Z+) first, then the Z- side. Of course I can't turn a whole sphere, there must be some material left on the Z+ side to hold the sphere.
    May 2006
    309
    Quote Originally Posted by hfjbuis View Post
    I uderstand, but have you ever tried to turn it around and cut off the rest of it in order to make a completely round ball like this one: this one?
    Mar 2015
    426
    No I didn't because I didn't need an aluminum or wooden ball!
    You could of course make some kind of holder that grab's just around de sphere without making indents. then you could turn the last portion round.
  1. Wrapping around a sphere?
    By Ecmdrw5 in forum Mastercam
    Last Post: 07-16-2013, 04:18 AM
  2. Object on a sphere
    By moosbach in forum Rhino 3D
    Last Post: 04-07-2011, 01:49 PM
  3. milling a sphere
    By bookwurm99 in forum MetalWork Discussion
    Last Post: 12-25-2010, 08:38 PM
  4. Grinding a Sphere
    Last Post: 04-04-2007, 12:56 AM
  5. Sphere on lathe
    By jorgepease in forum MetalWork Discussion
    Last Post: 09-09-2006, 03:53 PM
