587,999 active members*
2,303 visitors online*
Page 1 of 2 12
Results 1 to 20 of 25
    Apr 2012
    72
    Large concrete, epoxy high speed vertical CNC mill.
    Hi everyone.
    I've been collected parts for a while. This is time to upload some pictures and the design of my concrete based CNC. It's a heavy CNC for poor man. 3 tons and less than $300 for the frame.
    XYZ travel is 500x400x400 mm. The overal dimension is 1300x600x1900 mm. It weights less than 3 tons.
    And the parts:
    2504 NSK double nut ball screws, C1-C2 precision grade:
    Here is the head of this project. I got it for $400. It's used and come with the original box.
    3kw, 334Hz, 20000 RPM, 6*7xxx C P4 bearings inside.
    FK ball screw support:
    And let's get started:
    16,20,25mm steels:
    And the scale:
    XY saddle for your imagination:
    Thanks for watching!
    Khoa
    Aug 2004
    782
    Re: Large concrete, epoxy high speed vertical CNC mill.
    This is, by far, the best milling machine build on the site.
    Its the only one I have seen with real rigidity.
    Well done.
    Sep 2005
    1195
    Do you start with new project? how about the last one, you skip it. I like to see till finish your previous project.
    Apr 2012
    72
    I work on both at the same time and will update the progress soon. The spindle looks small in those pictures but It weights 40 kgs.
    Aug 2009
    291
    Sanity. I think you've misplaced it!
    Jan 2011
    38
    Are your casting it in one piece? It might be too late but I recommend you cast in two pieces. otherwise the column is going to be a pain to align properly
    Aug 2009
    291
    And throw some blocking at the bottom of the form, roughly where a couple of forklift forks would go!
    Apr 2012
    72
    This frame will be putted near the machine to carry the rough/heavy blocks for machining.
    Also for the frame. I will cast the ready made Z axis (milling and grinding) to the YZ column at one time.
    The Y axis will be aligned later by a thick layer of granite epoxy (about 75mm)
    Here is the Z axis. I'm working like a turtle.
    Thanks for watching
    Very good project..
    Sent from my C1 using Tapatalk
    Jul 2014
    215
    Love those heavy duty weldments. Looking forward to watching your design progress.
    Paul H.
    Apr 2012
    72
    I'm so sorry. I was heavy drunk last night...(chair)
    Aug 2009
    291
    Quote Originally Posted by khoac3 View Post
    Oct 12, must have been one hellova party!
    Mar 2010
    156
    I am really looking forward to seeing you progress after the last machine. Post lots of pics!
    Apr 2012
    72
    Hello. How are you guys. It's been a long time since my last post. The machine is gonna build up now.
    The YZ based is in shape now.
    Thanks everybody for following the thread.
    Apr 2012
    72
    Quote Originally Posted by Winterwatchers View Post
    I cast the ZY in one piece as you can see only the Z axis is on the concrete. The Y axis will be aligned later with a "thin" layer of granite epoxy (about 7cm).
    @asuratman: You can see the last one in the pictures I've posted here.
    Apr 2012
    72
    Here are more updates in this thread:
    The concrete is dry now and ready to move up.
    It took me half day to instal the linear rails.
    After a day with friends help and the winch, the concrete is steady stand up and looks like a machine now
    And happy lunar new year from Vietnam to all cnczone buddies. :argue::argue::argue::argue::argue::argue::argue:
    Mar 2004
    1306
    Cool mill project
    Regards,
    Mark
    Apr 2012
    72
    Quote Originally Posted by RotarySMP View Post
    Cool mill project
    Thank you Ii appreciate it
    May 2013
    70
    Ironically I am doing something similar. Ive got a thread running on mycncuk forum. Ill post something on here too. Nice build. Im also using large high quality components and will end up with a machine weight of around 2 tons.
    May 2013
    70
    Not to thread hijack (ill start my own) but size / scale of some of my machine bits...
Page 1 of 2 12
  1. Large Epoxy Granite Vertical CNC Mill
    By petruscad in forum Vertical Mill, Lathe Project Log
    Last Post: 10-08-2022, 10:45 PM
  2. HIGH SPEED SCALLOP VERTICAL WALLS
    By dfearnow in forum Mastercam
    Last Post: 02-28-2013, 07:07 PM
  3. Replies: 6
    Last Post: 02-22-2012, 10:09 PM
  4. Epoxy Concrete CNC mill 700x500x400 Design and Build
    By JohnMcNamara in forum Epoxy Granite
    Last Post: 01-25-2012, 07:34 PM
  5. Replies: 10
    Last Post: 04-30-2011, 07:09 AM
