guys,
I'm not a Fadal expert and nether is our operator.
we have had numorous errors regarding the y axis fixture offset being centered to the a-axis. most recently, the offset has gone from y-.035 to now y+.026!! all other axes have been consistent.
as i'm not at the machine much, im having trouble figuring out what is going wrong. mechanical (only two bolts holding rotary) or control operation error or a problem with the machine (bad CS switch).
the operator claims to send the machine home at night and CS in the morn the same everyday.
the manual lists multiple coordinate systems, why?
1. machine coordinate sys
2. tooling coord sys
3. fixture offset
4. program coord.
is there a page where one can see, machine pos, absolute pos, distance to go etc.. like a normal mill????
N94850 G94 Z7.7527 F20.
N94860 M5
N94870 G90 G0 H0 E0 Z0.
N94880 M1
N94890 ( 3/4 FLAT ENDMILL TOOL - 20 DIA. OFF. - 20 LEN. - 20 DIA - 0.75 )
N94900 T20 M6
N94910 G0 G90 S3500 M3 E1 X-7.075 Y0. A-327.11
format 2, btw.
if the a axis was at E1 A0 before the tool change shouln't it still be there after (but bufore reading new a location)???
