587,236 active members*
3,832 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Multicam Machines > Multicam Router/Doesn't follow mastercam Z depths
Results 1 to 7 of 7
    Oct 2009
    21
    Our shop bought a Multicam router 3000 series which doesn't read G code the same way are HAAS mills do.
    At the Routers little hand held remote the operator needs to set the max depth and adjust it. This fly’s in the face of what I program the router to do with Mastercam.
    If I program the parts with the fixture surface (wood) Z0 the router will not cut through the Material. Instead the operator needs to lower the max depth setting (material thickness) to cut thought the material.
    I believe that the router over rides the Z addresses posted by the Post sent to me from Mastercam. Is this right? Does the operator need to set the depth of cut at the machine? Not the programmer?
    Also, the router reads Z negative addresses as positive and Positive as negative. Is that right?
    Where in the hell is Z zreo at? Anyone know?
    Jan 2007
    599
    Z 0 is where you program it at, you can set it to the top of the material or at the bottom of the material, max depth is a safety thing, you set it to the top of your spoil board. It's so that if you messed up your program you don't run your cutter right trough your phenolic top.
    further reading trough your post, no the router should read negative as negative and vice versa, do you have the correct post for mastercam?
    May 2004
    4519
    I have never operated a Multicam router. I have only seen 2 of them. I think I read on the Multicam web site that they actually reverse the Z. Z-X.X is up, away from the table. Z(+)X.X is down, toward the table. Z-0.25 would be 0.25 above your material. If you were routing 3/4" plywood, Z0.75 would be cutting through your material.
    MultiCam - Support - M & G Codes
    Jan 2007
    599
    Quote Originally Posted by txcncman View Post
    yep, you're right. Im a multicam guy and to me positive means going down into the material. Do you have a user manual for the machine?
    Oct 2009
    21
    xjdubber yes we do have the manual for it and I will be reading it tomorrow. But during the day today I reposted using varying z positions and the machine everytime need the max depth adjusted just to cut thought a sheet of .05 7050-0 alu.
    Oct 2009
    21
    I discovered how she works.
    Z Zero is the surface of the material and the max depth needs to be set to the deepest Z the program will be going too minus the material thickness.
    So if I’m going too Z-.12 to clear a drill tip angle and the material is .05 thick. The max depth needs to be adjusted to -.07 from the fixture surface.
    May 2004
    4519
    Instruction manuals are wonderful tools. Too bad so many do not use them.
  1. MultiCam router machine
    By tote_ts in forum DIY CNC Router Table Machines
    Last Post: 11-29-2019, 05:29 PM
  2. Replies: 14
    Last Post: 09-18-2011, 03:11 AM
  3. Want to update Multicam router
    By Benonymous in forum Commercial CNC Wood Routers
    Last Post: 06-22-2009, 09:14 PM
  4. Australian multicam cnc router
    By BGH in forum Australia, New Zealand Club House
    Last Post: 07-16-2008, 11:58 AM
  5. Bobcad on new Multicam router
    By StephenSebastia in forum BobCad-Cam
    Last Post: 05-18-2008, 12:47 AM
