588,246 active members*
4,421 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Controller Options for PM30-MVL
    Oct 2004
    298
    I'm starting to rethink the controller for my PM30. I'm nearly complete with the conversion and in a few weeks I will transfer the electronics from my other mill over to the PM30. Currently, I am running 570oz-in motors for the X and Y, and have a ~700oz-in motor for the Z. The X and Y stepper drivers are 5056Ds and the Z axis is some generic driver I bought awhile back. I plan on upgrading the Z motor and driver.
    The question is... Should I just switch over to the MX3660 (and get rid of my current drivers) or just replace the Z driver with an 8070D to drive a new ~900oz-in motor? I am currently using a C35 breakout, but am looking to get an ethernet smooth stepper.
    The MX3660 looks nice on paper, but I'm wondering if the 5056D and 8070D combo would be better, since I don't necessarily need the breakout feature of the MX3660. I'm running a 48V supply for what it's worth.
    YouTube Channel: https://www.youtube.com/c/RobertCowanDIY
    May 2008
    1185
    Re: Controller Options for PM30-MVL
    You don't say the current or voltage of the generic drivers so its a bit had to reply.
    The Z is fairly heavy so a full current driver would be best. I think the 5056 driver only delivers 4.5 or 5A peak so you might want to get a true 6A driver like the Gecko.
    I have run the 900 oz stepper at 5A at 50V on the Z and it worked fine but only got about 80 IPM with the lower voltage.
    youtube videos of the G0704 under the name arizonavideo99
    Oct 2004
    298
    the Z has the generic driver. I think it's just a few amps. The stepper is a 2A, but it has really high inductance, so it needs a lot of voltage. I don't really plan on keeping either.
    The ~900oz-in motors I've been looking at shouldn't really benefit from a higher voltage. I could go higher if I wanted. but I think ~52V is their max beneficial voltage.
  1. Best ethernet controller options out there....
    By Menatep in forum Stepper Motors / Drives
    Last Post: 05-12-2014, 04:10 AM
  2. No options on controller
    By ncushman in forum Fanuc
    Last Post: 02-07-2012, 12:49 PM
  3. Controller options
    By cknowlto in forum Controller & Computer Solutions
    Last Post: 11-04-2009, 10:15 PM
  4. Controller options
    By cknowlto in forum DIY CNC Router Table Machines
  5. Controller options
    By cknowlto in forum CNC (Mill / Lathe) Control Software (NC)
