587,700 active members*
3,411 visitors online*
Hybrid View
    Jan 2008
    Spindle Noise
    I have a Daewoo Lynx 200B, I have noticed that the spindle, when spinning is getting louder. However, when spinning by hand, it is still extremly easy. My first thought is the bearings (I hope I'm wrong) does anyone have any experience with this same problem? Could it be something other than the bearings? The lathe is six years old, very light duty machining.
    FXRGUY
    Nov 2007
    13
    Any heat? Is the nose behind the chuck getting hot? With out beeing at the machine, its asking alot to decribe a bearing problem. It may be money well spent to call your Doosan dealer and have them take a look.
    Aug 2005
    578
    Belts can couse some strange noises. I've got a Haas that I swore the spindle was dieing. Opened it up and the belts needed attantion. Did that and the noise went away.
    Jul 2005
    17
    We have a Puma with a very noisy spindle. When we had a tech here for service on our 2500tl he told us the belts needed tightening on the Puma. seems like a simple fix we'll do when we have downtime.
    Jan 2008
    136
    The spindle bearings will be noisy if they are worn or damaged. To check them it is best to remove the belts to take tension off the drive pulley. you can then check for lift and end float in the spindle using a 0.0001" indicator and a bar. put the bar down the spindle and try to lift it using a bit of force. look at the deflection of the indicator, it should have no more than 0.0003" lift and it should spring back to zero. Use a plastic hammer to gently tap the spindle forward and back, there should be no more than 0.0002". The spindle should feel smooth to rotate with no lumpiness. refit only good belts and never overtighten them.
  1. spindle electrical noise
    By balsaman in forum CNC Machine Related Electronics
    Last Post: 06-02-2013, 12:01 AM
  2. keep the noise down!
    By SIMONSIGNS in forum CNC Machine Related Electronics
    Last Post: 12-04-2008, 06:42 PM
  3. How do you deal with the noise from the spindle pulley?
    By david_geng in forum Syil Products
    Last Post: 07-08-2007, 12:03 PM
  4. Way Oil and Spindle Noise
    By ETM Shop in forum Syil Products
    Last Post: 01-29-2007, 04:06 AM
  5. Porter cable spindle noise reduction or alternative?
    By paulr4 in forum DIY CNC Router Table Machines
    Last Post: 03-26-2005, 07:56 PM
