587,999 active members*
4,768 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > 100000 rpm spindle home made
Results 1 to 7 of 7
    Mar 2011
    Wink 100000 rpm spindle home made
    thinking to bay 2 ceramic bearing and ( ER11 C8 100L Collet Chuck ) on ebay
    and bay brushless motor BLDC Inrunner Motor esc can connect to pmv 10v with resistor i read that ESC need 0.29volt to start i goes to 0.69volt maximum
    the power adapter 12v 10amp for esc or to bay ( brushless motor checker ) nice looking for cnc is only 7.2volt hummm maybe it works with small high speed motor
    is easy to make and i really need 100000 rpm im cutting coper with 0.2mm 20deg the best is to have speed
    any Recommendations can it be done
    for small motor about 150watts silent and with ceramic bearing
    ESC or brushless motor checker and how to connect so it can stop when it is finished
    regards
    Jun 2010
    100,000 rpm?!?!?!??!
    Aug 2009
    899
    There is no need for 100,000 RPM for copper or any other material in milling. What are you trying to make because I have seen a .2mm end mill...... more information is needed.
    Apr 2010
    294
    A small gas turbine might be suitable to drive this.
    Jun 2007
    3891
    the er11 chuck likely isnt going to be balanced to better than 30krpm, less if its a cheap chinese one.
    your bearings with an 8mm shaft wont be rated for 100000rpm unless they are p2 grade pure ceramic with a cooling jacket. even then youl have a hard time with alignment.
    you wont be able to get a belt drive going that speed with any reliability, so youll need a direct drive which will limit the speed.
    the rc motor is not going to work. the motor is likely rated for 50-60k rpm max due to bearing limitations, and the 150W is peak current draw which in an RC motor is "meltdown" current. realistic usable power would be 1/4 to 1/6 that. on top of that these motors are not meant to run more than 5 minutes at a time. they are built to be as light weight as possible with tiny aluminium shafts. they just wont last more than a few hours running in a spindle if that.
    Mar 2011
    Question i try everything
    I bought air spindle 70000 great and I do not have enough air with my compresor then I bought a dental handpiece 50k 70wata and is ok silent geat
    but it can be superb
    The problem is it uses engraving bit 10deg 0.2mm and 1mm copper cut with a minimum speed of 250mm-min 0.1mmdeap very small piece
    if i make bldc rc motor i will have 60000 rpm if someone knows any motor like
    scorpion brushless can work 200 deg i read the is impossible to break
    scorpion inrunner or something like that
    Sep 2006
    6463
    Hi, thinking outside the box.....the new Jaguar C-X75 all electric concept car uses two micro gas turbines to produce the electrics for the batteries....micro turbines run with air bearings at about 100,000 rpm....anything with balls at this speed soon self destructs, air bearings are totally frictionless and don't need lubricating ever.
    If'n I was thinking of constructing a spindle in this rev range I'd be designing with air bearings and an air turbine to get the revs.
    Ian.
  1. Home Made internal spindle stop!
    By widgitmaster in forum Mini Lathe
    Last Post: 08-13-2016, 10:46 PM
  2. My home made cnc - Need a good spindle?
    By Rajpage in forum DIY CNC Router Table Machines
    Last Post: 11-02-2010, 09:03 AM
  3. Hard drive servo spindle are any good for home made lathe?
    By patriciooholegu in forum Servo Motors / Drives
    Last Post: 12-08-2007, 04:48 PM
  4. Home made EDM
    By RFERG43 in forum Waterjet General Topics
    Last Post: 08-29-2007, 12:18 PM
  5. Home made CNC mill (and some products made by it)
    By gcamlibel in forum DIY CNC Router Table Machines
    Last Post: 04-05-2004, 11:54 PM
