588,457 active members*
5,163 visitors online*
Results 1 to 10 of 10
    Feb 2005
    753
    I want a gantry type machine
    I would like to build a gantry type milling machine.
    I would like to do ice carvings.
    Please if you can steer in me in the right direction please do so.
    Feb 2005
    753
    I am interested in making something like this. Just double the size.
    [ame="http://www.youtube.com/watch?v=meZBUQbGDqA"]YouTube - DIY CNC Gantry Mill - Lionclaw LC50B[/ame]
    Feb 2005
    753
    Feb 2005
    753
    I know this second one is 5 axis... I believe.. that would be harder to make huh?
    Dec 2004
    411
    I would look at the different logs on this site and determine which best suits your needs.
    I guess mdf is out for ice.
    happy reading
    Andy
    Drat, imperfection has finally stopped working!!
    Feb 2005
    753
    Quote Originally Posted by andy_ck87028 View Post
    happy reading
    Andy
    Well some use a MDF table and MOST use a UHMW table..
    I want to go with the UHMW table...
    So where do I get the parts? I want to go with Servo motors. Is there any blueprints on these things?
    Feb 2004
    1086
    A good approach for "bolt together" machines is aluminum extrusion -- look for various 8020 builds on this site. I sell a set of parts for use in building machines from extrusion. Alternatively, you could go for a kit from Joe -- see the various machines in the Joes2006 forum. Hope that's helpful.
    Ahren
    www.cncrouterparts.com
    Feb 2005
    753
    Quote Originally Posted by ahren View Post
    Ahren
    I don't need a "bolt together" machine. I have a welder and access to a machine shop.
    Sep 2006
    247
    Quote Originally Posted by MBG View Post
    Then you are well ahead of many on this site. Again, if you take some time and read the post for various machines you should be able to get an idea of what is currently being done. Since you can weld, look at other builds using steel frames.
    If you come back with specific questions after doing some initial reading on your own, you will probably get more helpful answers.
    Feb 2005
    753
    Quote Originally Posted by rlrhett View Post
    I have an idea on the machine and how I want it designed.
    The problem/question I can't figure out is how to get the linear ways going. How to set them up and what not.
    What are the types of ways you can get?
  1. Robotic Plasma table instead of a gantry type?
    By Hi-Vac in forum Waterjet General Topics
    Last Post: 09-28-2009, 06:58 AM
  2. What type of machine
    By BallisticFab in forum Uncategorised MetalWorking Machines
    Last Post: 12-15-2007, 03:02 AM
  3. Gantry type.CNC Mill
    By dex918 in forum Linear and Rotary Motion
    Last Post: 08-22-2007, 02:44 PM
  4. Karbunkles 1st Gantry Machine
    By karbunkle1952 in forum CNC Wood Router Project Log
    Last Post: 04-03-2006, 02:56 AM
  5. Gantry Machine Problem
    By Alex S.A in forum MetalWork Discussion
    Last Post: 09-02-2005, 07:36 PM
