Hello everybody
I'm ready to start my journey with macro programming.
My Lathes Miyano's (Fanuc 18TB) need some parameter changes.
Does enebody know witch ones?????
Please help.
Cheers
Hello everybody
Please help.
Cheers
I have 9932 bit #7 (1xxxxxxx)for the 18M, I would assume it is the same for the 18T.
Al.
Albert E.
Thank you
I'll try it......
I know I have to test it with:
#101=1
What is suppose to happen if it works???
You won't get an error?![]()
the contents of local var. 101 will =1
Al.
Albert E.
Al-
I changed it, and test it (#101=1). I get an alarm:
Illegal addres imput.
Is this good news??????
Cheers
Al -
Thank you
I'll keep playing tomorrow.
Time for a cold one.
Cheers
dont put it inside of the ( ), if you are.
just
#101=1.
Right -
When I use 101=1; I get an alarm
If I do 101=1 I do not get an alrm.
Anyway now..Ican not found the macro soft key to be ablo to se my variables.
I think I need the help of Fanuc.
But if someone outhere has any ideas......
Thank you all for you replies.
George
Push the offset button and then press the right hand arrow soft key. It should be on this page as another soft key appearing.
Jon
Thank you,
I got it now.
George
