603,319 active members*
2,797 visitors online*
    Mar 2010
    Masterwood project 330
    Hello, I'm Enrico from Italy and I'm new in cnczone.
    I'm watching to buy a used Masterwood project 330 with a numeric control CN10/c.
    I need to know if this control can read and execute the standard ISO code (g code) and if there is a limit of number of lines per program.
    There is someone that can send me an example of a program with different movements for this control?
    I ask pardon for my bad english.
    Thanks very much
    35494
    I don't know about the 330, But I used a Project 327 with a DOS CN10 control for over 10 years. It didn't use standard g-code, but it's g-code was very similar.
    Mar 2010
    Hi ger21, thanks for the quick answer.
    If the code is similar I can "translate" it.
    I have 70000 rows program, do you know if the cn10 control can execute it, or if i can divide it into small parts and execute in sequence automatically?
    Thanks in advance, best regards.
  1. Masterwood Project 319-323
    By Tarpin in forum Commercial CNC Wood Routers
    Last Post: 01-28-2022, 08:38 PM
  2. Masterwood/Holzher project 316-K Help
    By moultim in forum CNC Machining Centers
    Last Post: 07-25-2020, 09:56 PM
  3. Masterwood Project 317
    By joesmyname in forum CNC Machining Centers
    Last Post: 08-20-2019, 12:10 PM
  4. 1992 Masterwood Project 313 CNC Machine
    By martyn.hodges in forum Commercial CNC Wood Routers
    Last Post: 11-23-2012, 11:42 PM
