603,388 active members*
2,725 visitors online*
Thread: Gantry Mill
Page 1 of 2 12
Results 1 to 20 of 22
    Feb 2009
    20
    Gantry Mill
    After building a small cnc lathe and retrofitting a small round column milling machine (like bf-30) I decided to build something bigger.
    As always I took advantage of a good friend of mine to help projecting and building these stuff, Flavio. But this time I have to ask for help to Max, too.
    Considering the big machinery that I have access to (max's machines) we decided to build a gantry mill, with its base measuring 2500mmx1000mmx500mm.
    After a rough project, we started the building of the base.
    I will continue to post as the building advances.
    By the way the linear guides on the base will have 65mm (2 1/2 inches).
    Attached Thumbnails Attached Thumbnails proj_fresa.jpg   27022010289.jpg   27022010291.jpg   27022010293.jpg
    Apr 2006
    3498
    Very Nice build.. Is it made to cut STEEL?..
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    Feb 2009
    20
    Yes. The bent profile is made of 1/2 inch steel and the covers and internal support of 3/8 steel, and the table is made of 1 1/2 normalized steel plate.
    Apr 2006
    3498
    Quote Originally Posted by lcarrudajr View Post
    Thanks for answering... I am also working on a Big Router 10 feet x 12feet working area.. That will be able to Mill and Drill in 10" Carbon steel plates..
    Can you kindly answer my following Questions:
    1- What Spindle You will use? What is the Power rating (KW) and will you use VFD with it?
    2- Are you using Stepper Motors or Servo Motors.. Can you share with us what is the specifications of these motors?
    3- What material you will cut with this CNC ?
    Best Regards
    Feb 2009
    20
    Great work and great site Khalid.
    1) I didn't gave much thought to the spindle yet, but I will have automatic tool change, a 2.2 to 3.7 kw motor controlled with a inverter.
    2)I will be using two stepper motors for moving the gantry (X), one for (Y) and two for Z.
    The stepper motors are 12nm or 120 kgf each. Maybe for (Y) i will be using a 20 nm or 200kgf stepper motor.
    I will be using g203v gecko driver. I'm pretty happy with the 120kgf stepper and g203v setup. It's very strong, fast and affordable.
    3) Sorry, forgot to say "yes" to the last question. I will be cutting steel. But as this machine is built without commercial aspirations (home based machine), I might be cutting wood too (very sloooow cutting).
    Sep 2004
    412
    Holy Crap...
    That thing is going to be massive....
    G'job and keep the pictures coming.
    Aug 2009
    392
    Quote Originally Posted by Deviant View Post
    Holy Crap...
    I know! I looked at the CAD rendering, and assumed it'd be a bench-top machine. Those pictures showed me otherwise
    Feb 2009
    20
    I had the base painted to prevent rusting, and moved it to my home.
    I have chosen the moving gantry design to make it easier to fit it in my small home shop.
    Attached Thumbnails Attached Thumbnails foto fresa.jpg   IMG_0094.JPG   IMG_0097.JPG
    Feb 2009
    20
    The rails are here.
    I had to wait a little, I had to save money to buy the linear rail.
    If you pay attention to the photo you will see a 6¨ caliper.
    The rails are 65mm (2.55¨) by 2500mm (97").
    I will have I lot of work for the weekend.
    May 2007
    781
    If it is not too worn out I think I would be looking at CNCing that little planer mill you are using as a welding assembly table.
    Feb 2009
    20
    Quote Originally Posted by Andre' B View Post
    That machine belongs to a friend. At first I thought buying that machine to retrofit it, but it is very expensive here in brazil, so I started building one from scratch.
    I learned that is easier to build a machine from scratch than retrofit an old machine.
    The planer was used as welding table because I needed a flat surface to join two 1/2 inch "sheets".
    Feb 2009
    20
    Some more photos.
    Linear rails are aligned.
    Attached Thumbnails Attached Thumbnails IMG_0266[1].jpg   IMG_0267[1].jpg   IMG_0268[1].jpg
    Feb 2009
    20
    Z axis
    Here are the pictures of the Z axis support.
    It's made of a 2 inches steel plate.
    Attached Thumbnails Attached Thumbnails IMG_0329.jpg   IMG_0331.jpg   IMG_0392.jpg
    Feb 2010
    331
    i dont know, looking at it, i would be worried about deflection.
    Sep 2006
    1738
    I was just going to say that this machine is rather small...
    Man would I love to have a machine this big!!
    Apr 2006
    3498
    great work..what is the price of linear rails?
    Feb 2009
    20
    Quote Originally Posted by Khalid View Post
    here in Brazil taxes are high, so I paid only for those linear rails that are installed US$3.200,00.
    It's a shame.
    Jul 2006
    1256
    The cost in the US or Canada for rails and blocks of similar size is $5,332.80 US direct from THK.Are your rails AMT?Where are they made?
    Good work
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    Feb 2009
    20
    I think it os chinese. The web site is .tw
    Jun 2010
    13
    Wow. Awesome build. Any updates?
Page 1 of 2 12
  1. Gantry type.CNC Mill
    By dex918 in forum Linear and Rotary Motion
    Last Post: 08-22-2007, 02:44 PM
  2. YAG-M: Yet Another Gantry mill
    By nash in forum Mechanical Calculations/Engineering Design
    Last Post: 11-24-2006, 05:38 PM
  3. CI gantry mill
    By i_am_fubar in forum Community Club House
    Last Post: 09-13-2006, 03:38 PM
  4. My New Gantry mill project
    By Stevie in forum Vertical Mill, Lathe Project Log
    Last Post: 08-05-2006, 10:58 AM
  5. Mill/Drill vs. gantry
    By georgebarr in forum Knee Vertical Mills
    Last Post: 05-05-2004, 11:04 AM
