587,331 active members*
3,421 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Need a recommendation for stepper drivers
    Mar 2010
    14
    I'm posting this here and in the keling forum, so please don't shoot me!
    Can anyone recommend drivers for the x and y axes of my cnc machine?
    It's a 4x8 router table using IDC P33V motors geared at 2000 steps per inch. The motors are 1260 oz-in, 2A/4A for series/parallel. Here is the data sheet:
    http://www.danahermotion.com/website...Data_Sheet.pdf
    The power supply is 56V, but I could get something else if necesary.
    I'd prefer to use something inexpensive like keling drivers, but I would also consider gecko. I cannot use microstepping drivers since I have an old school flashcut box that doesn't put out a lot of steps.
    Thanks!
    Feb 2007
    4553
    Post
    TG,
    You don't need the Flashcut box if you use Mach3 and a inexpensive {$25.00} breakout board.
    http://www.kelinginc.net/c10.pdf
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Mar 2010
    14
    Quote Originally Posted by jalessi View Post
    TG,
    Jeff...
    That's what I should do, but I don't really feel like learning to use a different control program and a different cam program. I'd probably use the EMC2 linux program if I were to change it.
    The DXF interpreter in flashcut is pretty pathetic, so I do have some motivation.
  1. Recommendation low voltage [12v] stepper driver??
    By vladdy in forum Stepper Motors / Drives
    Last Post: 12-02-2007, 01:53 AM
  2. Need recommendation on where to buy Stepper drive
    By camsoft in forum Stepper Motors / Drives
    Last Post: 09-07-2005, 11:25 PM
  3. stepper drivers
    By Nilesh in forum CNC Machine Related Electronics
    Last Post: 06-23-2004, 02:05 AM
  4. stepper drivers
    By DDM in forum DIY CNC Router Table Machines
    Last Post: 01-19-2004, 07:58 AM
  5. Recommendation for stepper motor and driver
    By daddyhobby in forum Uncategorised MetalWorking Machines
    Last Post: 01-17-2004, 12:39 AM
