587,067 active members*
3,634 visitors online*
IndustryArena Forum > CAM Software > Mastercam > 4Th axis not rotating like I want. Simple cut, can someone help?
    Jan 2009
    245
    I am building a tube bending die, on my 4th axis Matsuura mill. I cannot get the part to rotate, in the "A" axis, (Parrelell to X axis, mounted on the right side). I want the endmill to rough out and finish mill, while the 4th rotates, continuisly while the Endmill will basicly just stay on center in the Y axis and just keep moving down, and then back up to other side while the 4th is rotating. All I can get the Cam software to do is rotate like 2 degrees then the endmill wants to go down and sink in the part and come up the other side, then keep doing the same action. I want a continuas rotation of the 4th, not a bunch of movements of 2 degrees then cut, then repeat.
    Attached Files Attached Files
    Nov 2009
    16
    Quote Originally Posted by blakemachine View Post
    Why you don't use lathe program,i think it better for your part.
    Dec 2008
    3122
    Rotate all your geometry 180 deg around the X axis to get the tool to come from the top
    ( I think it wants to go to the mid-point of the solid, but don't quote me on that )
    In your operation
    - use center point ON and pick the origin when asked when you regen , this makes the tool axis point at the center line....Try to use a "Lead" on the tool to stop using the point of the ball, say +20°
    - turn Filter ON, it will filter out tiny moves
  1. Rotating part along the z-axis
    By shneek in forum Mastercam
    Last Post: 04-11-2009, 01:33 AM
  2. Rotating NC program in over Y Axis
    By yaji63 in forum MetalWork Discussion
    Last Post: 12-26-2008, 05:21 AM
  3. Foam Cutting Rotating Axis
    By professionalcnc in forum Italian
    Last Post: 10-30-2008, 07:38 PM
  4. Rotating Nut Ball Screw for dual X axis
    By AeroKam in forum DIY CNC Router Table Machines
    Last Post: 08-10-2005, 05:05 AM
