603,340 active members*
3,968 visitors online*
IndustryArena Forum > CAD Software > Solidworks > How to change direction of wood grain
    May 2007
    312
    Hi, I am need to rotate the grain direction relative to the part and cannot find the option in appearances. I can live with it but would like the grain direction to be more realistic. Unfinished pine is the appearnace applied to the part.
    Jul 2009
    140
    As a general note, SW does change it's UI frequently, so posting what version of SW you're using helps.
    Right click the material. Go to Appearance, then Click on texture. In the Texture window, move down to Texture Properties. There should be a slider for sizing, and the one below it is for angle.
    Good luck!
    ck
    May 2007
    312
    Hi, Its 2010, I tried your approach and it did not lead me to the correct area. I did find by accident right click on selected part, select appearances icon, property manager opens on the left and has 2 tabs, select mapping, planar mapping icon, then slide rotation slider. Thank you, your information did help to locate this solution.
    Squirrel
  1. How to change the direction of cut
    By concombrefrais in forum FeatureCAM CAD/CAM
    Last Post: 07-10-2010, 01:32 PM
  2. Change X Direction on SL-5
    By C-4 in forum Mori Seiki lathes
    Last Post: 06-29-2010, 03:35 AM
  3. How do I change the direction of cut?
    By Ironworks in forum PlasmaCam
    Last Post: 05-08-2009, 04:53 AM
  4. milling end grain of wood
    By bookwurm99 in forum MetalWork Discussion
    Last Post: 11-23-2007, 08:02 PM
  5. Replies: 2
    Last Post: 02-27-2007, 05:46 PM
