586,834 active members*
3,104 visitors online*
Page 26 of 76 16242526272836
Results 501 to 520 of 1506
  1. #501
    Sep 2011
    1183
    Gerry thanks I followed the install manual and copied the other Macros to the folder. I think the other was there from when I installed it before my PC. crashed I lost some files and others where saved.
    Lou
    http://www.cnczone.com/forums/diy-cnc-router-table-machines/140832-cnc-software.html
  2. #502
    Sep 2011
    1183
    Question
    Gerry or anyone do you know how to get both touch plates to show active when testing them? I am only able to get one to show active I have the both hooked up to my Gecko 540 input3 when I go to ports and pins in Mach3 input signals I then use the automated setup I am only able to get one to show active on the 2010 screen set. It will show active on the one I last one I setup not both I have tested both and the both work I can setup the fixed but then the other don't work or I can setup the movable plate then the fixed won't work?
    Lou
  3. #503
    How exactly do you have them wired? They should each have a wire tied to a single wire going to the input. If one works, the other should work as well, as they should be connected?
  4. #504
    Reading you're post again, it really sounds like you have them wired to different inputs??
    You should only be setting up one time, as Mach3 doesn't know there are two plates.
  5. #505
    Sep 2011
    1183
    Gerry Thanks your right one was on input3 the other on input4 on the 540 I hooked both up to input 3 and it is working..:wee:
    Lou
  6. #506
    Sep 2011
    1183
    Gerry, I would like to say Thank You for all your help and a thanks for making the 2010 screen set I installed it and have tested everything It works great. Your Manual and videos are well done and to the point I am very happy with it thanks...
    Lou:banana:
  7. #507
    Sep 2011
    1183
    Ok I must have something wrong when trying to carve today I set material up used the one touch plate it worked like it should but then at cycle start it moved away from material and and stopped. I look at my 2010 screen it says hit cycle start after tool change. I thought maybe I hit the wrong button so I homed everything reloaded the G code and it did the same thing anyone know what is going on?
    Lou
  8. #508
    Your g-code has an M6 at the start, so Mach3 is waiting for you to change the tool. If you just click cycle start when asked, it will move to the fixed plate, reset zero, and continue cutting.
    You may want to modify your post to remove the first M6. If you send it to me, I can do it for you if you want.
  9. #509
    Also, if you're g-code has tool changes, make sure you use the Initial Auto zero that uses both plates.
  10. #510
    Sep 2011
    1183
    Do you want me to post the G code it is one of The VCarve files that come with the program?
    Lou
  11. #511
    If you just want the code edited, then sure.
    What I meant was to modify the post processor file.
  12. #512
    Sep 2011
    1183
    How do I mod the post processor? The file or g code only called for one tool a 90 degree V Bit..
    Lou
  13. #513
    If you use the ATC posts, they'll always have an M6 at the start, because a machine with an ATC has to pick up the first tool.
    There a guide to editing the post processor at the Vectric forums, near the bottom I think.
  14. #514
    Sep 2011
    1183
    Smile
    Gerry thanks I will fool with it tomorrow I used this..
    ( V-Carve 1 )
    ( File created: Wednesday, May 30, 2012 - 05:51 PM)
    ( for Mach2/3 from Vectric )
    ( Material Size)
    ( X= 12.000, Y= 12.000, Z= 0.750)
    (Toolpaths used in this file
    (V-Carve 1)
    (Tools used in this file: )
    (1 = V-Bit {90 deg 0.5"})
    N100G00G20G17G90G40G49G80
    N110G70G91.1
    N120T1M06
    N130 (V-Bit {90 deg 0.5"})
    N140G00G43Z0.8000H1
    N150S16000M03
    N160(Toolpath:- V-Carve 1)
    N170()
    N180G94
    N190X0.0000Y0.0000F100.0
    N200G00X2.6598Y4.8228Z0.2000
    N210G1Z-0.1992F30.0
    N220G1X2.5956Y4.7864Z-0.1628F100.0
    N230G1X2.5368Y4.7555Z-0.1319
    N240G1X2.4833Y4.7295Z-0.1058
    N250G1X2.4472Y4.7143Z-0.0907
    N260G1X2.4128Y4.7022Z-0.0786
    N270G1X2.3880Y4.6953Z-0.0717
    N280G1X2.3661Y4.6909Z-0.0673
    N290G1X2.3396Y4.7117Z-0.0409
    Lou
  15. #515
    Sep 2011
    1183
    I also use the Mach2/3 Arcs(inch) (*.txt) for Post Processor out put..
    Lou
  16. #516
    Just take out line 120, with the M6
    N120T1M06
    I'll upload the modified posts that I use later today, if you want to try them.
  17. #517
    Sep 2011
    1183
    Gerry thanks I will remove N120T1M06 sure upload I would like to try them..
    Lou
  18. #518
    Sep 2011
    1183
    Gerry removing the N120T1M06 line did the trick everything is working right...
    Lou
  19. #519
    I'll get the new posts for you a little later.
  20. #520
    Sep 2011
    1183
    Thanks Gerry..
    Lou
  1. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  2. Econo-Probe Setup with Mach3 + Ger's 2010 Screenset
    By jmc2010 in forum CNC Machine Related Electronics
    Last Post: 06-24-2014, 04:21 AM
  3. G100 + Mach3 2010 screen auto tool zero
    By Menatep in forum G-REX
    Last Post: 05-02-2014, 10:13 PM
  4. Strange Issue with 2010-4 Screen Set in second machine profile
    By JoeKumanchik in forum Mach Software (ArtSoft software)
    Last Post: 03-30-2014, 11:27 PM
  5. New Mach3 Router Screen
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 03:06 PM
