586,913 active members*
2,978 visitors online*
IndustryArena Forum > CAM Software > CamBam > Can't open/import an Inventor STL file
Results 1 to 7 of 7
    Aug 2010
    Hi- I'm just trying out CamBam and I'm having some problems. I made a simple part (cone) in Inventor (R 2009) and then exported the part file (.ipt) as an STL file, which CamBam can apparently import. When I tried to open the file I see "Input string was not in a correct format" at the bottom of the application.
    Has anybody else had similar problems? Any suggestions?
    Nov 2008
    412
    I'm cambam user and on rare occasion i get the same error. The problem file I open in MeschLab (open source, free program) ans save as stl. Cambam is happy so i'm I...:rainfro:
    Forget about global warming...Visualize using your turn signal!
    Aug 2010
    Thanks, the MeshLab workaround worked. Looks like it modified the structure of the STL file created by Inventor, and it then works with CamBam.
    Feb 2005
    521
    Apologies for this... a bug introduced in 0.9.7f when trying to read some text format STL files. Binary STL files work OK.
    This bug has since been fixed in version 0.9.8
    www.cambam.co.uk
    Oct 2006
    Hello All, I'm in the learning process of the CAD >> CAMBAM process and have found that I have ( I think ) the same problem as described so far. I get the error of "input string not in correct format" when trying to import an AutoCad .dxf file. I've tried saving various flavors of the .dxf ( ie different autocad versions, as well as binary and ascii types as well) Get the same error. I've downloaded the latest locked version of the CAMBAM code...so any suggestions would be appreciated. Thanks in advance.
    Addional info>> I've also tried the latest development release as well. Same error.
    New News >> I shutdown and restarted the programs. Using the latest dev. release and importing an AutoCad 12 ASCII .dxf file I was successful in importing and being able to manipulate the drawing and machining assignments. So far so good..
    Feb 2005
    521
    CamBam can not currently read binary format DXF files.
    Text format DXF up to ACAD 2000 is the preferred option.
    More file formats are planned for 0.9.9 - we will look into adding binary dxf support.
    www.cambam.co.uk
    Oct 2006
    current Status -
    Thanks 10Bulls for the prompt reply - I've muddled through all the file type options one at a time, and have managed to export a workable file to Mach3 and have successfully cut a part with the design. I like the CAMBAM layout and useability, and working through the sample program examples> ie the stepper motor bracket < illustrated the steps necessesary to create a part file. I'm sure I'll be back at the trough for more tips and guidance as I forge ahead with this project, so thanks again for the support.
    Mike
  1. Inventor Import
    By roninB4 in forum Autodesk
    Last Post: 06-19-2010, 05:18 PM
  2. Replies: 4
    Last Post: 12-28-2009, 11:12 PM
  3. Import stp file in NX
    By blmmdes in forum UG NX
    Last Post: 09-11-2008, 03:40 AM
  4. inventor file imports
    By keebler303 in forum Autodesk
    Last Post: 02-27-2008, 01:18 PM
  5. file import
    By motomitch1 in forum OneCNC
    Last Post: 03-25-2005, 04:08 AM
