603,800 active members*
3,864 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Doosan Lynx 220 Gang Tool or Turret?
    May 2010
    I am looking at the lynx 220 series as well. I am looking at the gang tool option and the turret option for high volume turning. I am leaning towards the gang tool. Am I giving up any rigidity in the machine by going with a gang tool option? Is the turret more rigid, or does it not matter? I need to drill a fairly deep hole in my part, not anything with a tight tolerance, just 10 times diameter. My interest in the gang tool is faster cycle time and less things that can go wrong in the future. We have never run any gang tool lathes, always conventional with turrets. We have had Miyano, Hwacheon, Haas, and Mori. Any help would be appreciated. Thank you.
    Mar 2009
    10
    hi,
    Gang Tool is recommended if you have only 2 ~3 Tools.
    Or Else Turret Type will do the better job.
    Doosan Machine you can index the turret any where as you like. It does not ask you for reference position for Tool Change. So we change time there.
    Also This has Dia 32 Tool Holding Capacity. A2 #5 Spindle Nose 6" Chuck. Where as you have flexibility in Turret type there are 3 (A,B,C)variants with higher torque.
    B and C Variants are powerful than Gang Type Model.
    Also Maximum Turning Diameter will be a Question mark?
  1. Doosan lynx 220 LC made in china?
    By philrace34 in forum Daewoo/Doosan
    Last Post: 12-31-2010, 02:49 PM
  2. Doosan Lynx 220
    By Schljuutene in forum Daewoo/Doosan
    Last Post: 02-12-2010, 06:44 AM
  3. Doosan Infracore Lynx 220LM
    By HelicopterJohn in forum Daewoo/Doosan
    Last Post: 08-02-2009, 11:44 PM
  4. Gang tooling vs turret
    By baldysm in forum Uncategorised MetalWorking Machines
    Last Post: 12-03-2007, 11:47 PM
  5. Gang tooling vs turret
    By baldysm in forum CNC Tooling
    Last Post: 11-29-2007, 06:03 AM
