603,371 active members*
4,489 visitors online*
    Jul 2010
    C&G Mustang - Limit Switch Error
    I've got a C&G Mustang plasma table with a Burny 5 controller and 4 torches mounted over a 12' x 24' table. We typically only use 1 torch, so we just removed 2 of the plasma torches to allow us to get closer to the edges of the table with the remaining torches. The small air lines to the torches have been capped and they, along with the signal lines, are laying neatly across the bridge. Now the Limit indicator light is lit up constantly and nothing will move without holding down the switch. All 3 of the limit sensors work perfectly. The screen displays "E-Stop" mode.
    Is there some kind of feedback loop the Burny 5 requires from all 4 of the torches to enable the table to move?
    Has anyone encountered an error of this sort before?
    Jun 2012
    I have the same machine and same problem, would like to know what you found out.
    Jun 2012
    I have the same machine and the same problem and was wondering what you found out
  1. Limit switch replacement with proximity switch?
    By Normsthename in forum Bending, Forging, Extrusion...
    Last Post: 07-11-2009, 04:38 PM
  2. limit switch error fool-around
    By draughted in forum LinuxCNC (formerly EMC2)
    Last Post: 02-18-2009, 11:17 AM
  3. Limit switch Error
    By friklin in forum DIY CNC Router Table Machines
    Last Post: 06-24-2008, 11:14 PM
  4. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
